SVS Cables
janmike
Well, it will be a SVS sub purchase, not exactly sure which one at this point. (SVS PB10 or PB12)
1) The SVS subs apparently come with a heavy duty power cord. How do you SVS owners feel about the cord and have you replaced it?
2) Has anyone purchased the Better Cables Interconect from SVS when purchasing the sub? Just wanted to know how they compared to the other interconnects people are using.
Thanks Folks.
Thanks Folks.
Michael
NORTH of 60°
NORTH of 60°
Post edited by janmike on
i can make you a good cabble for a good price. the better cables are good but they are a little pricey
Ready, Aim, Fire.Michael
NORTH of 60° -
Get the PB12. More is better.
Replace the stock cord with Signal Cable. Consider it a minor tweak.
Get a less expensive subwoofer cable. No need to get fancy with a sub cable. Any decent RCA cable will work well.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Thanks Early B. I am just trying to justify an additional $220 Cdn $ for the PB12. I like bass, but do not need to crack any pictures or things like that.Michael
NORTH of 60° -
Don't expect a performance gain from changing the SVS's power cord, you won't get one. Put that $ towards the biggest SVS you can afford.
The only reason I would upgrade an SVS power cord is if you needed a longer one.
Regards,
PolkThug -
Janmike, let me know how the whole customes thing work(s)(ed) out!
Geez! Not worth it, man.I am just trying to justify an additional $220 Cdn $ for the PB12.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I agree, $220 for what. Nice sub, but the PB10 will suit me fine. The 3 metre cable for $26 (Better Cables from SVS) seems like a good deal. I need a cable and 9 feet is a good length. I would pay that for a 6 ft. interconnect from RS anyway.Michael
NORTH of 60° -
Is that all? Yeah, go for it. Didn't they used to cost more than that?The 3 metre cable for $26 (Better Cables from SVS) seems like a good deal.
Enjoy the PB10.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
SVS/Bettercables Subwoofer Interconnect
3 Meter Interconnect
RCA to RCA
For all powered subs
$26.95 (When you buy a sub)
Bettercables link
PRICE FROM bettercables.com
Your Shopping Cart
Item Options Unit
Price Qty. Subtotal
Better Cables Silver Serpent Audio Interconnect Cable Stereo Pair
Connectors: RCA/RCA
Length: 3 m (9.84 feet)(+20.00) 64.98Michael
NORTH of 60° -
Wow.
$64.98 vs. $26.95 for the same cable. Looks like one helluva markup when you buy direct.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
