xrt12 discretes
cowboy
are these posted somewhere on the polk website?...found some on remote central for the pronto, but did not have preset discretes
Post edited by cowboy on
Are you asking for dicretes similar to "Preset Bank A Choice 3"? There is no such thing unfortunately. Requests have been made for this feature and would be included in any future products.Brian Knauss
ex-Electrical Engineer for Polk -
So, are these posted somewhere?
thanks -
Are you asking for a direct way to get to Bank A or Bank B (example: you're in "direct" mode and you want to go straight to Bank ? The only way to get to the preset banks is to toggle through "direct"-->"preset A"-->"preset B"
In case you don't have that code, it is:
RC5 27 98, or
5000 0000 0000 0001 001B 0062Brian Knauss
thanks for the help, that was not what I wanted to hear, though.
I was looking for a discrete for the Banka/Bank B/direct - not a toggle code....jeez, I guess the only code which is truly a discrete is the ON/OFF.
Very dissapointing....I don't get it...there is rs232....but no discrete for the ONE toggle code on the unit
