does this exisit
aequitas
is there any adapter that would let me plug two banana plugs into one.
Post edited by aequitas on
Never ran across a banana adapter before.
OK, I gotta ask -- what are you trying to do?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Got bi-wire cables and speaker that aren't bi-wireable?
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
I think you guessed it....and if that's the case you could get banana to spade adapters and put two spades to one terminal.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
If that IS the case, which I'd say there is a greater chance than zero it is, sell the friggin bi-wire cables, and get something to suit your application.
Cheers,
RoosterCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Yes....that would be the logical thing to do. Or else remove the bananas and go bare wire or re-terminate if you like them so much you don't want to get rid of them.
Why add another connection?2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
actually, i wanted to try making some jumpers and i have extra banana plugs to attach to wire. so i was looking for an adapter that would let me plug the speaker banana plug in and also a banana for the jumper to connect to the other terminals. just trying to mess around and try some different things that arent going to cost me too much. but since it seems this device doesnt exist ill try something else. thanks
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=091-1260
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=091-330
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=263-582
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=091-334
There are more, high tone options, ie WBT, and some Monster - which I will NOT endorse.
Cheers,
