Sonic impact project complete *pics*
faster100
Ok well i completed the power supply for my modded SI amp.. here are the pictures hooked up to the dodd and the sda1b's.. sounds fantastic... The power supply consists of a transformer from a wall wart and a mallory 50v large uf capacitor (big and anodized blue lol) ran a computer type cord hard wired and a piece of this same wire that has a connector that fits the outlet of course on the amp.. shrink wrapped up and looks clean, green led on the power supply and blue led on the amp both switched with a matching on/off switch... lemme know what ya think..
alittle satin clear coat and they would match the dodd's finish exactly
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
2MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
3rd and finalMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Cool!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Nice job, Cliff. How does it all sound?
I run this in the bedroom on rt25i's and a parasound pre and it sounds great.. i tested it on the main 2 channel rig on tubes and sda's and it still sounds great!! alittle less bass on the big speakers and the amp does have it power output limits on these big speakers.. however i havent clipped the amp and it doesnt distort at higher volumes.. i think in part to the nice cap i installed in the PS, before the cap it ran out of steam at less then half volume.. It was a fun project.. not really cost effective .. but considering what you get for under 50 bucks complete its worth it. small, powerful, cool factor, clean sound and on tubes really laid back. i love the single led's on the front.. clean simple and bright...
THE key to this amp is ample power... on wall warts it did distort just as madmax had mentioned.. on a large 14amp ps i used it never gave up a bit.. and on a xformer capped it works fine..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Very cool looking rig. Are those Ampex Bugle Boys I see in your Dodd? How do you like the sound?
Maurice -
YUP amperex bugle boys.... nice smooth sound.. kinda light on bass.. but still sounds firm on bass, I have a 7308 on the way to try on the output, being this only uses one tube for output.. I think, lolMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
