7.1 Question
P.HUNT
P.HUNT Posts: 211
Ok I have a 25L x 17W room and my rear speakers are all the way back against the wall about 10 feet behind me and 16 feet appart.
If i go 7.1 is it ok to mount the rear surrounds about 3 feet directly above the surrounds? And how far appart should they be?
And is it worth going through the trouble,time,and money or not?
PROCESSOR-- Sherbourn PT-7010A
AMP
Sherbourn 7/2100A
DVD
DENON 3910
BLU RAY
PS-3
PROJECTOR --- Panasonic ae-900u
SPEAKERS
Klipsch Ultra2 System
92" Screen
PS Audio power cords
Buttkickers
  • PolkThug
    PolkThug Posts: 7,532
    edited May 2005
    Try to get them between the surrounds, so you can get the full effect of ES/EX soundtracks.
    Backwall:
    [4]
    [6]----[7]
    [5]
    I guess it depends on your room, mounting them higher might let the sound carry easier to your listening position. You could experiment by putting them on a ladder and listening.
  • P.HUNT
    P.HUNT Posts: 211
    edited May 2005
    my layout will look verry similar to your diagram.
    ok i just wasn't shure if 7.1 only worked well with surrounds that were placed beside the listiner then the surround backs behind the listiner like this
    [sb6]
    [sb7]
    couch
    [s4]
    [s5]
    AMP
    Sherbourn 7/2100A
    DVD
    DENON 3910
    BLU RAY
    PS-3
    SPEAKERS
    92" Screen
    Buttkickers
  • PolkThug
    edited May 2005
    Originally posted by P.HUNT
    [sb6]
    [sb7]
    [s4]
    couch
    [s5]
    This is like my layout, TOP-DOWN perspective.
  • Skynut
    Skynut Posts: 2,967
    edited May 2005
    I would experiment, I would drag wires across the floor and prop speakers on ladders or boxes or even hang them from brackets. listen to how they sound for a movie or at least several of your favorite trailers.
    Once you figure where you want them then run wires and all that fun stuph.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • unc2701
    unc2701 Posts: 3,587
    edited May 2005
    I'm with skynut- nothing beats experimentation, because every room is different- I thought I had my surrounds in the right place, but moving them back about 3 feet made a world of difference...
    For 7.1, you need to get something like lord of the rings, or a test disc... there aren't many discs with more than 5.1
    Backburner:Krell KAV-300i
  • aaharvel
    aaharvel Posts: 4,489
    edited May 2005
    Any "6.1 DTS-es Discrete" disc will be a good experimentation disc. I think LOTR special editions are in 6.1 DTS-es, but not the original plain editions that i have- just Dolby 5.1 ex. =(
    Gladiator is my top pick for 7.1 in my collection. Hannibal and Terminator 2 are both OK- but they're processed in "5.1 DTS-es Matrix".
    i wonder when they'll actually come out with "7.1" for DVDs. Not that they REALLY have to- DPL IIx makes everything sound quasi-7.1 - and the results can sometimes be so good in my little room of 20L x 14W x 10H it's crazy. =)
    Front- rti-4
    center- csi-3
    side- f/x300i di
    rear- f/x300i bi
    sub- Velo CHT-10
    Pre/Pro- H/K 235
    Amps- Adcom 5300, 7300
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • P.HUNT
    P.HUNT Posts: 211
    edited May 2005
    my layout will look like POLKTHUG's drawing except r6 and r7 will be about 2 feet above r4 and r5.
    AMP
    Sherbourn 7/2100A
    DVD
    DENON 3910
    BLU RAY
    PS-3
    SPEAKERS
    92" Screen
    Buttkickers
  • PolkThug
    edited May 2005
    You'll be fine! :)
