good brand subs?
96montecarlo
96montecarlo Posts: 17
edited May 2005 in Car Audio & Electronics
I used to have some cheap DUAL subwoofers powered by a 1200w sony amp. I'm getting rid of the box&subs. From what I hear bandpass is known for sloppier bass. I will probably get a sealed. I was wondering what is a good brand subwoofer that won't cost me an arm and a leg. I really need that leg. lol
(And what type of box would be better? I was thinking when I get enough money to get a mdf box and cover it w/ fiberglass for a custom look. Will this work?)
Post edited by 96montecarlo on
  • exalted512
    exalted512 Posts: 10,735
    edited May 2005
    you know, ive always heard good things about Polk;)
    -Cody
  • 96montecarlo
    edited May 2005
    ive never used polk subs. Are they pretty good. I know that I'm HIGHLY impressed with my speakers. I wish they made a HU and I would be good to go.
  • MacLeod
    MacLeod Posts: 14,358
    edited May 2005
    Polk does not need to make a h/u! SPEAKER specialists (well and amp specialists now:D )!
    Yes the Polk line of subs are excellent sound quality subs. Ill put them up against any sub at twice their price.
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited May 2005
    One thing too remember...the sound you get...is not just related too the sub. Box is just as...if not more important then the sub itself. Find a good sub.. (kicker,adire,image, Polk(cough),alpine,and many more too list....but be sure the box is too the spec's of the sub (designed for the sub) and built properly. You can get a great sub... with a poor box and come up with cow dung! One needs the other.....hope this helps you out some.
    peace
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    edited May 2005
    Check this out, you will not be dissapointed, and best of all you can ebay both items..
    First Off
    Orion 12" H2.2 (Dual 2 OHm Voice Coils for a theoretically 1 ohm load in parallel), personnaly I have measured it and have found mine to be .8 ohms)....so I left it at 2 for my set up.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18803&item=5776537576&rd=1&ssPageName=WDVW
    And the box that meets the manufacturers recommendations.
    Subzone Vented Box
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=50568&item=5771556081&rd=1&ssPageName=WD1V
    Again, I can vouch for this, as it is sitting in my audi's trunk, has been for about a year and a half, using a JLAudio 500 to push it. Go with a 1000 if you can afford it.
    My buddy has the Jl 1000 pushing the JL W7 and my orion/JL set up is IMO as good, and less expensive.
    In closing, there are many good amp/sub combos out there, and one already hit the fact that the box is as important as the sub. So ensure you get the right box for the right set up. BTW the subzone is at least 3/4" MDF
  • SamSagaZ
    SamSagaZ Posts: 321
    edited May 2005
    one question abt subs box... if the sub is recommended for 25L and my box have 26L the sub will sound bad?
    is hard to measure right the volume with an fiberglass box :D
  • 96montecarlo
    edited May 2005
    try building a box and then covering w/ fiberglass to fit your trunk. I hear this works.
  • SamSagaZ
    SamSagaZ Posts: 321
    edited May 2005
    i already have my box...
  • 96montecarlo
    edited May 2005
    well maybe you shoulda put more thought into it. I'm sure the size diff won't matter MUCH.
  • MacLeod
    edited May 2005
    peace
    Excellent point.
    No.
