Ceiling mounted fronts??
Todd Lee
Todd Lee Posts: 73
Long story short, I'm setting speakers up for mother-in-law. 60" t.v. set in the room on an angle (not flush with wall, rules out wall mounted fronts.) I think she wants to stay away from anything on the floor, she wants things to look clean...
The question:
Is it o.k. to use ceiling mounted speakers for fronts? I'm talking the in ceiling speakers, not hanging down.
The room is large, roughly 25' X 30-35'. Seating is about 15 feet from screen.
Also, if anyone has any speaker recommendations for this size room, while still keeping the cost under $600'ish, for 5 plus sub, I'd appreciate it!
Thanks,
Todd
Pioneer 1018
Polk RTIA5's
CSIA6
RC80I's
SVS PB12-nsd
Post edited by Todd Lee on
  • unc2701
    unc2701 Posts: 3,587
    edited May 2005
    Short answer: bad idea.
    Long answer:
    Ok, so go look as this graph (nothing special about this speaker, it just happens to show off-axis response):
    http://www.partsexpress.com/pdf/297-305.pdf
    Notice how the frequency response gets really bad for the 30degree and 60degree off axis lines? Apart from the fact that all the sound is going to be coming from above the action (on the TV) , they're going to sound really boomy and you'll have trouble picking out dialogue. That said, if you must do it, make sure you get ones that have tweeters that pivot, so you can point them at the listening position.
    Backburner:Krell KAV-300i
  • Todd Lee
    Todd Lee Posts: 73
    edited May 2005
    Thanks so much for the info!
    I've pretty much decided on ceiling mounts for the rear, and probably towers for the front.
    Most likely:
    Rear
    Polk RC60i
    Center
    Polk CS1 Center Channel
    Front (towers)
    Polk R30,
    or Monitor 50
    Subwoofer
    Polk PSW12,
    or Velodyne VRP- 1000
    Any suggestions/comments??
    Pioneer 1018
    Polk RTIA5's
    CSIA6
    RC80I's
    SVS PB12-nsd
