Help, I can't see my TV!!
smalltownheel
What do you guys use (blinds, curtains, etc) in your HT rooms to block light?
Post edited by smalltownheel on
You can:
1. Move HT room to basement.
2. Watch movies at night. -
Vertical blinds work good in our family room to stop light coming through the windows from the setting sun. Reasonably priced.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
2 layers of 3/4" MDF, Dynamat, and curtains.
F the WAF!
And yes, I am married, but she has her other living room she make make as pretty and dainty as she wants. This one's MINE!!!
BWAHAHAHAGo BIG or go home! -
Ditto on the vertical blinds. Its not perfect, but does an adequate job.
Try wood blinds. They seem to block out the light better then the plastic ones.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
I think I am going to try both, Wood blinds and some sort of heavy curtain. (Like in the no-tell motel)Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Thanks for the responses, I guess I'll try both vertical blinds and curtains.
