what abt Ground?
SamSagaZ
SamSagaZ Posts: 321
edited May 2005 in Car Audio & Electronics
hey, from where i need to get the GND of my amplifier? from the battery or just for the Chassis of the car?
(sorry for my dumb question)
Post edited by SamSagaZ on
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    edited May 2005
    I am making a huge assumption here, (not really), your ground cable from your battery is attached to your car chasis, firewall, etc. So your chasis is common ground to your (-) terminal...
    So, you can hook it up to either, good news for you, personnaly I have my amps (-) ground bolted to the car in the trunk.......whatever you prefer....do unhook your battery first before you start messing with that amp.
  • MacLeod
    MacLeod Posts: 14,358
    edited May 2005
    Hook your ground to the chassis of the car.
    Make sure you get a solid mount, and use a ring terminal.
    Also, be sure to sand away all the paint around the area the terminal will mount.
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited May 2005
    Rule of thumb... Ground should be same size as the Power...and you really want to keep it within 18"-24" of the amp. Other wise...the chance for noise in the system will increase . (notice I said chance)
  • SamSagaZ
    SamSagaZ Posts: 321
    edited May 2005
    mmm
    thanks guys, but now i dont understand very well :D
    TrappedUnder Ice, ur saying that is better to use an wire directly from the batter?
  • MacLeod
    edited May 2005
    No. He's saying its best to have the ground no more than 2 feet from your amp.
    This is why its best to ground to the chassis.
    Pick a spot to ground and make sure the ground wire isnt too long.
  • exalted512
    exalted512 Posts: 10,735
    edited May 2005
    when he says same size, he means same gauge of wire, like if youre using 4 awg for power, then use 4awg for ground as well
    -Cody
  • SamSagaZ
    SamSagaZ Posts: 321
    edited May 2005
    thanks guys you are the best :)
  • swerve
    swerve Posts: 1,862
    edited May 2005
    Originally posted by SamSagaZ
    thanks guys you are the best in bed :)
    fixed it.
    cats.vans.bag...
  • TrappedUnder Ice
    edited May 2005
    in my stay at keeping it simple...guess i should have been more specific. thanx for clearing up the loose ends....hehe
