EQ problems
rayburnjd
rayburnjd Posts: 4
I have hooked up a Yamaha GE60 EQ to my AVR, as stated in my owners manual. I have no accessory jacks, so I am using the Tape jacks.. REC OUT to the INPUT of the EQ... and the PLAYBACK to the output of the EQ.. I am not running a Tape player. It doesn't work, and I am wondering if there is some setting that I am overlooking.
Post edited by rayburnjd on
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2005
    I think you'll have to select your source with the "tape monitor" switch in that configuration, leaving your main source selected to "Tape 1" or whichever input the EQ is on. Depending on the EQ, you may have a switch on it that needs to selected as well.
    I have to ask, why an EQ?
  • cnjvh
    cnjvh Posts: 253
    edited May 2005
    Also be sure the tape loop you're using is a Tape MONITOR loop - many AVRs have a tape rec/play loop that is not a tape monitor loop. If its simply a tape loop, your EQ will only work when the tpae input is used on your AVR.
    A tape monitor loop lets the AVR route audio from any non-digital input on the AVR through the EQ attached to the tape monitor loop. There will be a tape monitor button somewhere on the front panel of the AVR that will have to be pressed to engage the loop.
    Also, even with a monitor loop, you will only ever EQ the main right and left channels.
    No earth robot is going to tell ME which button to press!!
    --Stuff--
    Front: Polk Audio RTi12
    Center: Polk Audio CSi5
    Surrounds: Polk Audio RTi8 (x4)
    Sub: SVS PB10-ISD (Dual)
    AVR: Denon AVR-3805
    Blu-Ray: Panasonic BD30
    Display: Sony KDL-55NX720B
    STB: Xfinity X1DVR
  • BobMcG
    BobMcG Posts: 1,585
    edited May 2005
    Steve sort'a took the words right out of my mouth, err off my keyboard, or from some place, but at any rate..... yeah, why stick an EQ into the signal path??
  • rayburnjd
    rayburnjd Posts: 4
    edited May 2005
    well, mainly because I have the room in my rack, and thought I could maybe tweek things a little, however being that my AVR has just the tape loop, and not a monitor loop, I dont think I want to re-install my tape deck, just to use the EQ, so I believe my EQ venture is over.... maybe I will use the room up with another amp :)
  • steveinaz
    edited May 2005
    There ya go. EQ's are EVIL.
  • amulford
    amulford Posts: 5,020
    edited May 2005
    Oh, come on. Evil??? maybe a little ornery, but evil???
    I use them. It's a personal preference. But you can use them to overcome some room deficiencies. The secret is not to over use them.;)
  • steveinaz
    edited May 2005
    Your right brotha, when used correctly they can be very effective, unfortunately most use them as "super" tone controls.
  • aaharvel
    aaharvel Posts: 4,489
    edited May 2005
    Right on the $ Steve.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
