upgrade queston.
goingganzo
goingganzo Posts: 2,793
edited May 2005 in Electronics
ok i have a realey nice setup but would like to upgrade.
my pre amp is a sunfire theater grand III<---love it
my amp is a adoon 7607 <
possible upgrade
my prijector benq 8700+ <---- new and great
speakers 800i,400i and fx 500i <-posible upgrade
if i do amp with amp should i go for? and if i do speakers with ones and or diy but there is no kit i realey like. exppt that are a real advanced kit
Post edited by goingganzo on
  • hamzahsh
    hamzahsh Posts: 439
    edited May 2005
    Your system is already excellent. I don't see any reason to upgrade. Leave everything the way it is and buy more DVDs and CDs and enjoy them.
    :D
    Panasonic TH-50PX80U Plasma HDTV
    Polk Audio RT800i (fronts)
    Polk Audio CS400i (center)
    Polk Audio F/X1000 (side surrounds)
    Polk Audio RTi6 (back surrrounds)
    Velodyne CHT-15 (subwoofer)
    Yamaha RX-V1400 (Pre/Pro)
    NAD C272 (2-ch Amp)
    Adcom GFA-7605 (5-ch Amp)
    Toshiba SD-3109 (DVD/CD player)
    Malata DVP-580 (Multi-region DVD player)
  • Skynut
    Skynut Posts: 2,967
    edited May 2005
    I have the RT5000p system and love it, I also have extra center speakers and love them. I would recomend changing the amp first so you can see the advantage with the current speaker set up. then change the speakers. then figure out what you think is the weakest link and change that. then start the process all over again.:D
    What about wires?
    power cords?
    It really is never ending but the benifit is you do not have to sell anything till you see what the new component sounds like. (you may not ever sell of the old equipment.)
    the three u's on home theater.
    Upgrade
    Upgrade
    Upgrade
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • McLoki
    McLoki Posts: 5,231
    edited May 2005
    If you want a complely new sound I would upgrade the speakers. Get some really good speakers (whatever brand trips your trigger) and put them in your front location. (phanotom center for now - polk rears) If you really dig the sound, (your current amp runs the new speakers fine) get a center. If not, get a new amp and then a center.
    Some amps just sound better with different speakers. If you are even thinking of upgrading the speakers, I would get them first, then the amp.
    Magnepan (if you can deal with the placement of them) sound great. I also really like Vandersteen. (the Vandersteens really need the right amp though - I have heard them sound like crap with the wrong amp.)
    Just listen and then get what you like. I am guessing bass will not be much of an issue for your speakers, so you may look at really nice 2 way speakers (with your IB sub) and see if you like the way they sound.
    Michael
  • gregure
    gregure Posts: 871
    edited May 2005
    Magnepan are electrostatic speakers, and I think Martin Logan make better electrostats. Make sure to check out both first before considering a purchase. Also, the Martin Logans are easier to place and do not take up as much space.
    If you like on-walls, the Martin Logan Frescos are pretty awesome, as are the Vienna Acoustic Weberns (better for music than the Frescos). The Weberns are around $800 a speaker, where the Frescos are about $1000 per speaker.
    If you want to stay in the Polk family, I'd certainly recommend checking out the LSi series.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
    heiney9 Posts: 25,428
    edited May 2005
    Definetly upgrade speakers if you looking for a different sound. Your equipment is excellent and you'd have to spend a chunk of money to improve the amp. Different speakers will make the biggest impact/ difference. The speakers you have now are good, but there are many out there that are much better. (Just ask Steveinaz about his new Energy C9's) The hard part is choosing and demoing the new speakers. If you go used pretty hard to retrun if you don't like. If you buy new make sure they have a good return policy.
    P.S. A whole set-up of Lsi's would really improve not only HT but 2 channel as well.
  • tonyv1
    tonyv1 Posts: 365
    edited May 2005
    Maggies are planar magnetic speakers. Electrostatic require high voltage to charge the stator to operate, the Maggies do not, check here for a detailed explanation. Class over, thanks.
  • aaharvel
    aaharvel Posts: 4,489
    edited May 2005
    speakers all the way.
    you sound like a guy that might be happier outside the realm of Polk speakers, even the LSI's (sorry Matt)
    If that's the case, I cannot help ya.
    My Rti's and F/x's are the nicest speakers i've ever owned or heard- LSI's included.
    I would recommend BOSE to you- but you're not the one that killed my rabbit and boiled him on the stove. ;)
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Skynut
    Skynut Posts: 2,967
    edited May 2005
    Oh no not the bunny.:eek:
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
