Sub advice....
rayburnjd
I am deciding which Polk Sub will best suit my needs, I have SDA-SRS in front, and R30 in rear... and not really sure how much sub I need, for instance if a PSW120 would be enuf ?? any ideas?
Post edited by rayburnjd on
Get SVS Sub instead,u will not be disappointed!!!!very funny!!!TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear -
To enhance/outperform the bass from your front speakers (I assume the big SDA-SRS'), you'll need to go a lot higher than the Polk subs. Check HSU, SVS, Rocket, Velodyne and some paradigm subs and find what you like. You can often times check around to get demos of the HSU, Rocket, and SVS subsThere is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
SVS. With subs, the bass you can't hear (IE below 20Hz) is just as important as the bass you can (in my opinion).
http://www.svsubwoofers.com/subs_pb10_isd.htm
Oh, and I'm not biased or anything just cause I have two of these!!
Send these guys a mail with your room dimensions etc. and they will find you the right solution.
No earth robot is going to tell ME which button to press!!
--Stuff--
Front: Polk Audio RTi12
Center: Polk Audio CSi5
Surrounds: Polk Audio RTi8 (x4)
Sub: SVS PB10-ISD (Dual)
AVR: Denon AVR-3805
Blu-Ray: Panasonic BD30
Display: Sony KDL-55NX720B
STB: Xfinity X1DVR -
how big is your room?
the room is 15 x 15 however, not completely closed in, one side kind of opens in to another part of the house...
i looked at and listened to a lot of subs before i decided on my velodyne dls-500r. with a room that size a 12" from hsu, svs, or velodyne (my fav) will sound great. take a look at the velodyne dls-4000, i think you will be very happy with it.
