help
anumericrae1
can i use a 2 channel amp to power up my two subs?
Post edited by anumericrae1 on
Little more info is needed.
What amp?
What subs?
are they svc/dvc
what are the ohms of each -
If you mean bridge the amp to a pair of 4 ohm, single voice coil subs the answer is not likely. There arent too many amps out there that are stable to 2 ohms mono.
If you mean running each of them off a single amp channel then yes.
If they are a pair of 4 ohm DVC subs you could wire each in series which would be 8 ohms each then bridge them together which would be 4 ohms mono.polkaudio sound quality competitor since 2005
