passing it on
Willow
If you could go back in time, what would have been the ONE piece of A/V advice you wish you had known before buying ?
and what would be the one piece of advice you currently think is important?
Post edited by RyanC_Masimo on
Don't "settle." Get what you want the first time around, if it isn't available or you don't have enough money, wait until you do.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
You nailed it on the head first time around Steve.
Thread closed"she had the body of Venus, with arms." -
DOH!
Thread back open!! One point to Zero!:D"she had the body of Venus, with arms." -
Along with the above mentioned item.
1.Buy a receiver with pre-outs so that you can upgrade/ or expand with an amp/amps.
2. Buy used.
If I would have followed those two I could be looking at amps and have a much better receiver. Instead of being stuck. DOH!Beer on tap is great, until the keg runs dry and the liqour store is closed!:D -
Refurbed with a warranty gives the best of both worlds.
Value and security.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Advice then:
Listen to systems 25%-50% over your pricerange before you purchase and then determine if you are still happy with your current selection. Many of my purchases were made based on budget, not sound. It would have saved me alot of rebuying if I would have had this advice.
Current advice:
Research then buy. Amazing how many times this happens in reverse. (sometimes still does....)
Before even getting into this hobby research like mad... make sure you know what you are buying instead of just wing'in it and buying something.
I wish I had gone 2 ch from the start... not nearly as much need for fancy surround since I listen to music 95% of the time. -
get it clear to your mind that
1- finding some top gun and new modles as an used one ,,i would say "good luck"
2- refurbished : only and only with the same warranty as new one , worth looking for it.
3-suggestion as : 25 percent higher than your budget ,,, in most cases it is worth it.
4- dont even think because 90 or 95 percent of the time you listen to the music ,therefore you will not need more than 2 ch,, you will be sorry big time. you dont know what you will be missing.
5-check and double check throughout the net and forums to have the best knowledge for what you are paying for.
6-dont forget that having the best A/V without a good speaker or reverse one is a total of waste of money,,unless you are planning in very close future to match them. -
A point for michael_w!
HT is not all it's cracked up to be. Build a good 2-ch rig. Used equipment gets you much more for your money. If you buy good equipment, it will have some value left when you decide to upgrade. If you buy cheap crap, you might as well just flush the money.
Jason -
Lol I disagree... I havn't watched a movie in my room in over 2 months. If I had spent the cash I did on my HT system at the moment I would have a nice new CDP and amp or something increasing the 2 ch system that much more where the quality of it would be so much better than my current ht system that I would want to watch movies on the 2 ch system instead...
I've watched full movies in 2 ch by accident (forgot to set to surround setting on receiver) that I didn't notice until the end of the movie when I went to shut if off. That was with my ht system in 2ch not my 2 ch system and I didn't notice enough difference to see that it wasn't in 5.1.
edit: wait I'm a little confused what you're trying to say here. Are you saying that people should just go 2ch and skip a ht system or that people should get a ht system because it sounds so much better than 2 ch for movies. -
I'm sorry but there is no way I could confuse 2 ch with my surround system.
My advice would be find the best you can afford and surpass it.
When I started, I started with speakers and worked my way up.
Chances are you will not be happy ever. you will allways want something better than what you have so buy the best you can now and plan replace it when you can.
experiment and learn from each poor choice.
I am partial to home theater and the fact it plays real good music is a bonus. I love hearing the movies better than they sound at the theater, music is something I listen to while I am cleaning house or playing on the internet.
Figure out which media you like most and build that way but never think you can do the best the first time.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Thanks every one, keep going!
I thought it would be nice if some new peeps would read this and learn from our past experiences.
Mine would be don't buy on impulse. If I had listened to that I would have saved lots of cash. -
If you can't afford separates, make sure you get a very good receiver with preouts so that you can add separate amplifiers to it later on. Then when you can afford to get separates you won't have to get the amps because you will already have them.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
