AE: Symphonies preamp...make it work?
rnp614
I just got ths preamp from someone off the forum and I plugged it into one of my sources, plugged in my audire amp, plugged in the power cord and turned it on with my amplifier and I get no sound. Is there something I'm missing about tube preamps or what should I check?
Post edited by rnp614 on
Hrm seems that my audire seems to be the problem. I hooked it up to my other preamp where it used to be connected and now I'm not getting out of it. I hooked up my carver amp to the AE and it works. What do I check on this amp? When I turn it on the light still goes on. Could I have blown a fuse somehow?
checked the fuse on the audire and it seems to be ok
i just cant plug ti back in again! haha damnit i really just dont know what I'm doing right now! -
FYI, weed and electronics do not mix well. Wait till you come down and then try again2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
ok, coming off the high....so I put the fuse back in, plugged one speaker into the audire, one interconnect between audire and rotel preamp and nothing. Just bass bc the sub is still hooked up. What else can I check on this amp? What could have happened?
problem averted...thanks Russ!
