ohms
Toando
i know that less amp gives more watt to the speaker, but i dont know the different in sound. is the lesser the ohm the better or the more ohm the better?
thanks
thanks
Post edited by Toando on
Your amps will probably run hotter at ther 2-ohm load, and I am pretty sure there is a slight reduction in sound quality as well, but I'm not sure how noticeable it would be.
Anyone else? -
well,
If your speaker is made to handle 4 ohms then you should wire it to drawl 4 ohms off of the amp. Most car stereo speakers are 4 ohm. Different number of ohms aren't always better or worse, more ohms (or a larger number of ohms) drawls less power while less ohms (a smaller number of ohms) drawls more power from the amp. Ohms are just a measurement of the resistance against the flow of electricity.
