Help with Receiver to Computer hookup
PatH
Hi,
I connected my receiver to my brand new dell computer today, and I have to turn the receiver up to 6 just to be able to barely hear it. I am using some car RCA cables that I had lying around, but they are good Rockford Fosgate gold plated connectors. With the CD player I have hooked up to it I turn it up to 2 and it is loud. Has anyone else had this similar problem?
Thanks,
Pat
Thanks,
Pat
Post edited by PatH on
What is the volume of your computer, or sound software set at?
nevermind guys. I was hooking up RCA cables to my computer DUH!! ok so i got a cable that had a headphone like connection on one end and then RCA's on the other and it is working like a champ. Does that mean I have mono sound now?
Thanks,
Pat -
It depends on the cable you bought. I belive some come in stereo but mine seems to be a wierd mono like sound. It takes one channel (either left or right) and blends it across to the two speakers creating one channel mono instead of stereo mono if that makes sense...
Thanks,
Pat
What soundcard do you have? You might also want to experiment with sending digital SPDIF into your reciever.Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010 -
It is the stock 5.1 integrated sound with the dell 8400 pc.
