wiring
Toando
hi can i use one 8 guage wire and use a distributor and distribute it into two 8 guage. and how away from he battery should i install my distribution block?
thanks
thanks
Post edited by Toando on
Probably be a good idea to use 4 guage from the battery to the block then 8's from the block to the amps. It shouldn't technically hurt anything to do 8 to 8, but the power draw will be very limited. And I believe the distribution block is supposed to be as close to the amps as possible.Testing
Testing
Testing
