newbi questions on bi-wire,
MSALLA
MSALLA Posts: 1,602
Although I've always had decent equipment, I never got into details.
Can anyone explain a bi-wire set-up and what are the benefits.
I'm just getting into playing with audio systems so I may ask some dumb questions from time to time.
Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880
Post edited by MSALLA on
  • unc2701
    unc2701 Posts: 3,587
    edited May 2005
    Biwire requires that you have speakers with two sets of binding posts on the back. You detach the jumpers connecting these and run two speaker cables from the amp to the speakers- one for the highs and one for the lows.
    Most people do not notice any major benefit from biwiring- the biggest benefit is that you double the wire guage, so if you have low impedence speakers and/or long runs, you'll probably hear an improvement.
    Backburner:Krell KAV-300i
  • MSALLA
    MSALLA Posts: 1,602
    edited May 2005
    Do you run both wires from the same outlet on the recevier?
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • unc2701
    edited May 2005
    yep. works best if you cram both of 'em into some banana plugs, then use those to hook to the receiver. Otherwise it's a nightmare of one or the other falling out while you try to screw down the post.
    BTW- I said it wrong, you don't double the wire guage- but you do have a more wire/ less resistance.
  • McLoki
    McLoki Posts: 5,231
    edited May 2005
    I think it is wire gauge - 3. i.e. double runs of 16ga. wire = 1 13ga run. double runs of 12 ga wire = 1 9ga run.
    Michael
