Rechargeable Batteries
brettw22
Do any of you guys/gals use rechargeable AA batteries and if so, what brands have you found to be longer lasting than others?
My brother has a digital cam and he's won't consider anything other than rechargeables, so the only thing I've been looking at spec-wise is the mAh rating for each battery. The Duracell has a 2300 mAh rating which seems to be the highest, and I'm assuming means it would last longer than an 1800mAh rated battery, right?
I have not experimented with brands, just buy the one's on sale. Last price paid was $4.50 for a 4 pack of off-brand 2000 mAh.
mAh explained:
Scroll down past the comparison chart to the section: "Watt-hours vs mAh and Simple Run Times".
http://www.imaging-resource.com/ACCS/BATTS/BATTS.HTM
Some batteries for sale here:
http://www.thomas-distributing.com/aa-nimh-batteries.php
A few recharger reviews:
http://steves-digicams.com/digi_accessories.html -
Duracell, there is no substitute.Political Correctness'.........defined
President of Club Polk -
I've used the Lenmar NoMem Pro with their speed charger. Worked great. The Powerex products are always rated highly as well.
Although Duracell may make great alkalines, their rechargeables are nothing special. Energizer does however make some pretty good rechargeables. -
I don't use name brands. I have two pair of Rayovac 1800mah NiMHs... those are the only name brands.
I then have 4 or 5 pair of "Digital" 2200mah NiMH, and one pair of Vanson 1800mah.
I have found no differences between them, except the "digital's last a little longer being of a higher mah. Biggest difference is rapid-charging vs slow charging. I have both chargers, and I still use my 14 hour charger because the batts last much longer that way.
For comparison, when I first got my digicam, (A Gateway DC-M42) I could take 11 pics before normal alkaline batts would die. I can now take nearly a full card (170pics) with 1800mah batts.Ludicrous gibs! -
I use batteries from http://batteryspace.com/
I use some cheap o's and some monster power batteries... both seem to work similiar and last a long time.. it depends what you use them for as to what power rating you would need.. if its a motor driven piece, camera with zoom lens, cam corder or just a simple light... or non moving item its not as critical.. and the batts will obviously last longer..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
i use 2800mah... they last long, you can even feel they weigh more on your hand.
POWEREX Batteries.
Example:
My Canon digital will take 9-12 pics with 2 AA duracells.
It will take 350-400+ with the powerex batteries. How much more proof do you need? Buy a Maya charger to go with them.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
You're not talking 350-400 on a single charge, are you Steve?Originally posted by steveinaz
POWEREX Batteries.
Example:
It will take 350-400+ with the powerex batteries. How much more proof do you need? Buy a Maya charger to go with them.comment comment comment comment. bitchy. -
Yes! Powerex NiMH 2200's. They are awesome.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I've had a few guys at work swear the Monster batteries are hard to beat. But we all know our feelings about the Evil Empire.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
I've had a few guys at work swear that Bose is hard to beat.... would you listen to them?
Ludicrous gibs! -
I get 900 pics on my monsters
joking, But who takes 350 -400 pictures and keeps track? LOL of the battery life.. picture taking Mo-fo'sMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
I have a set of Power EX and a Maha charger as well, and they are they blow-away the Monster Powercells I had before.
Hey, I like the 901's when properly setup... so why can't monster make ONE thing worth while?Originally posted by nadams
I'll fully charge my monster **** bags and see how many pics it will take, random snap snap snap pics.. I'd actually be interested to know what they and others "actually" do....MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
The 4 cheap AA's I bought at Microcenter.com suck. They are called Ultralast with "up to 1,000 charges" but are heading south with under 50 charges.
For the first year I got at least a month's heavy daily use in a universal remote. Then they started lasting 3 weeks, 2 weeks, and now about 15 minutes.
I'm going for a name brand this time. -
In my experience, Energizers are great rechargeables. I use Energizer AA 2500 mah batts and the Energizer 15min charger. These things last a very long time in my Canon A620.
Highly Recommend.
Also, this is a great site for battery information:
http://www.batteryuniversity.com/partone.htm
Tells you when to charge batts, different types of rechargeables, etc. Very informative.
MikeReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
I use Radio Shack rechargeables for work items. I'm going to transition some into the house eventually as they work great.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
