Help with Audioquest
organ
I picked up a pair of AQ Type 4 speaker cable today. Each run have 4 individual wires in one large tube. 2 red, 1 black, 1 blue.
Now I need to make a +ve and -ve. I have no idea how the wire is braided inside. Do I connect red with red for the +ve and black with blue for -ve? Red with black and red with blue? Does it matter?
Also, can anybody tell me what kind of sound I should be expecting from these cables? Warm? Bright? forward? laid back? I'm currently using standard Mo*ster 16ga. It will probably be about a week before I try it out because I'm listening to the LSi9 right now. Oh yeah, the AQ is for my Klipsch not Polk.
Maurice
Maurice
Post edited by organ on
Ok, here's my input on this hope it helps.
Red 20 gauge to Black 17 gauge wire.
Black 20 gauge to Blue 17 gauge wire.
I'm thinking they are "Forward"
Unless you're connecting these bi-wired?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Warm and laid back is not a term I would use with AudioQuest. Not Bright...but detailed would be a good adjective... I know I like the way my Polks sound with AQs. Can't say about Klipsch."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
He didn't give me that option Detailed
BTW I do love how they sound with Polk....:)
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Red and red kills fred dead. black and blue makes you feel screwed.
Warm and fuzzy with a hint of Brutus overtones.
Okay I do not know what I am talking about.
SorrySkynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
BTW how do you like the King Cobras?"Just because youre offended doesnt mean youre right." - Ricky Gervais
Gotta think outside the box DJ7FS.
I think the Diamond Backs are much better? I felt that the King Cobras are too detailed too forward they made me turn down my stereo. I think they great for a small room 2 channel setup if you never turned it up too loud.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Thanks for the help, Disney. On the second one, did you mean to say Red to Blue? There are two red, one blue and one black. From the instruction you gave me, there are 2 blacks. btw, are they directional?
Shack,
That's good enough for me. I find their "Diamondback" IC to be very detailed and I wouldn't call them warm at all.
Skynut,
LOL:D.
Maurice -
I never worked with this cable myself, so I took this from their website as far as colors.
I do say small wire to a large wire for + / -, so it ends up as 15 gauge wiring.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Aaaah. Alright, I figured it out. I stripped the outer jacket and the small wires have markings on them so I know how to do it now.
I made a mistake. There are two reds and two blacks. No blue. One of them looked blue before I stripped the outer jacket.
The two larger ga are labeled "bass" and the two smaller ones are "treble".
Do you recommend I bi-wire or twist the "bass" and "treble" wires together and use jumpers? It looks like a very small wire. 20ga for HF and 17 for LF?
Maurice -
Maurice
That the magic of Audioquest small wiring for the frequency being passed. As far as the Bi-wire thing it's your call, I'm not a fan any longer of Bi-wiring. So I connect 1 bass to 1 treble same on the other side, but that's your call.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Thanks a lot for the help DJ.
I think I'm going to try bi-wiring first. It's going to be a pain in the **** to make jumpers out of these stiff **** cables:).
Maurice -
I would say they are detailed and smooth. Two reds together, two blacks together. I've always used them as a single rather than bi-wired other than when I used two sets of them. They are real easy to work with. The actual wires are very soft. So soft in fact that they conform very well to the posts and make an excellent contact.
Ditto. Detailed and smooth, but not necessarily laid back. Awesome speaker cable without a doubt.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Never worked with Type4 cable personally is there a small red and a large red. Alone with a small black and a large black. My input was based on the picture off AudioQuest website, (which is colored nothing like it is in really life.) so I hope I didn't mess anyone up.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Madmax,
Yeah, I'm very surprised how easy it was to work with. I thought the cables were going to be stiff.
Early,
You got that right. It's a kick **** cable.
It took me over an hour to prepare the cables and pretty them up with some heat shrink tubing. I know I said I was going to wait until next week to try them out but decided to hook them up (bi-wired) last night. I listened to them last night and all day today. Wanna break them in because I have a JJ and EH 6922 coming to the front door in less than 12 hours from now.
So far the Type4 is one amazing cable. I was using a pair of Polk Cobras but found them much too bright at high spl so I installed some 16ga leftover Monster stuff. The AQ kicked all their asses. I wasn't expecting a big improvement but damn. First thing I noticed is the clarity and detail. It made my previous cables sound sibilant. The bass is very impressive. It doesn't hang around in the front where the soundstage is. Now it's in the room. Imaging is much better too. I love it. The HF is awesome. The refinement I'm getting from the horn tweeter aproaches that of the Vifa in my LSi9. The dynamics increased as well. I'm not going back to stranded speaker cables.
I agree with what have been said about these cables. Detailed and smooth is a great description. I also find them to be on the dark side of neutral. Not warm but darker. They've had many hours on them and I have no idea how long it will take to break them in. So far they're worth every penny.
Next thing for me to upgrade is my speakers. The dealer (same one I got the AQ from) gave me a great price on a pair of Klipsch RF-7. But after doing a lot of thinking and reading, I think I'm getting a pair of La Scala. They have to special order the RF-7 and La Scala so no demo before buying. Hopefully they will be my last pair of speakers. That dang La Scala is 104db/w/m!!!
Maurice
