Adcom GFA 7500 channel problem
gwh
gwh Posts: 1,451
edited June 2012 in Electronics
Had my center channel unplugged on the speaker side and the wires touched, thought I had the amp turned off.....well I thought wrong. Opened the hood and replaced the fuse (it was fried).
Now the center channel thermal protect light stays illuminated, and still no output on this channel, all the other channels work.
What else can I check?
Sincerely, (ashamed and embarrassed )
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Post edited by gwh on
  • aaharvel
    aaharvel Posts: 4,489
    edited May 2005
    i have a 7300 and 5300.
    i would call Adcom or email them. They're customer service is regarded on these forums as pretty good.
    good luck.
    http://www.adcom.com/contactinfo.htm
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
    heiney9 Posts: 25,408
    edited May 2005
    gwh, (just edited the name)
    Adcom amps are built like tanks, and frankly one short like that shouldn't take out the output transistor. I know the 2 channel Adcoms have A.C. line fuses and D.C. rail fuses. The AC line fuse is accessible from outside the unit but the DC rail fuses are internal. Now I don't have any experience w/ the multi channel units so I can't say if there's more to look for. Have you checked the owners manual or checked the net, must be missing something. Again it would be very odd that one little short like would damage the outputs. But anything is possible :rolleyes:
    Have you had a chance to call Adcom yet?
    You can check the DIYAUDIO forum, but the threads can get a bit technical if you don't have a basic understanding of electrical circuits. Just do a search for Adcom. I did that recently but don't remember if your particular problem came up. Actually on that forum there are a lot of former Adcom techs who answer questions. Worth a try!
  • gwh
    gwh Posts: 1,451
    edited May 2005
    I opened it up again and peaked at the circuit board, didn’t see any obvious signs of sizzle.
    Guess I’d better contact Adcom.
    Thanks for the replies,
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • gwh
    gwh Posts: 1,451
    edited May 2005
    Well no reply from Adcom, guys on the DIY forum seemed to think it needed surgery.
    Anybody here repair Adcoms? Any of you Texas members know of a reliable competent repair tech somewhere just south of the Red River? Austin Texas looks like the closest authorized repair shop, really hate to tie $ up in shipping though.
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • unc2701
    unc2701 Posts: 3,587
    edited May 2005
    If you're like me you'd probably rather email than call, but the Adcom people are GREAT on the phone... Give them a call.
    Also- the DC rail fuse is the most likely culprit- look for a fuse on the channel module that's dead- oh, and be very careful poking around in there- some of those cap's will stay charged for awhile.
    Backburner:Krell KAV-300i
  • aaharvel
    edited May 2005
    e-mail them dude.
    They're no Outlaw or Polk Customer service- but you should get a reply within 3-5 days.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • niccolosito
    niccolosito Posts: 1
    edited June 2012
    gwh wrote: »
    Did you fix your center channel problem? Mind sharing the solution?
    Thanks.
    Nick
  • ben62670
    ben62670 Posts: 15,969
    edited June 2012
    Disconnect the thermal protection led from the board that says thermal overload protection. I learned this trick from an Adcom tech. No guaranties, but it is an easy "fix" sometimes. The channel is most likely not blown, and being the center channel it is highly unlikely to get over loaded like the mains would. If it works I would just run it;) Email me if you have further issues. I very rarely drop by here.
    Ben
    Ben
    nooshinjohn Posts: 25,889
    edited June 2012
    This is a 7 year old thread Ben....
  • ben62670
    edited June 2012
    I replied to someone who posted yesterday.
    Thanks John...
    BTW welcome to
    CP nick.
    Ben
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited June 2012
    I called Adcom for an unrelated problem.They do not answer directly w/ a receptionist or menu .You leave your # and they do get back to you. I didn't like that system but the tec Dave did call back.
