Selecting an amp
doug lang
Thanks all for taking my question. Looking at various used amps for my system, and here is my question. If I was to buy a higher priced amp at 5 channels, verses multiple amps to achieve the 5.1, What would be the advantages or disadvantages. I do know like I said price would be a factor. I am upgrading to the lsi speakers and I want to use them with a 5.1 system. Thanks Doug
Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Post edited by doug lang on
Biggest advantage is you would only have 1 big box & need 1 outlet for all of your speakers!
If I had known at the time that a separate amp would make that much difference, I would have saved my pennies & just purchased an Outlaw 755 & never have to worry about purchasing another amp again.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
You might look at this amp on Audiogon.
Outlaw 750
It has plenty of power for the LSi's, will be good quality, should still have three years left on the warranty, and is a great price.Tschüss
Zach -
Yes space, outlets and price. ThanksOppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
Thanks okie I will give it a shot. DougOppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
Outlaw 750
This sounds pretty good but he has no feedback and no picture.:(Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
All things being equal mono-blocks will sound better than a single 5 ch amp. Individual power supplies is one of the big reasons.
Phil
Music rig:
1.2s front
2.3s rear
2 cs400i center
Shure 12" sub
2 PSE mono blocks and 1 stereo amps front
2 PSE stereo amps rear
1 PSE stereo amp center
Mac 2100 bridged to mono sub
B&K ref 10 upgraded to ref 50 pre/pro
Harmon Kardon Citation tuner
Pioneer tuner for AM
Pioneer DA-45 universal player
Sony X7esD CD player
Technics 1200 TT
PSE pre amp for the analog stuff -
Where would he plug all of those monoblocks into? I just have 1 outlet on the wall where my equipment is & I have 2 power strips plugged in to it. 10 pieces require power, 2 of which are my amps. If I had 5 mono's I wouldn't have enough left over for all of my other equipment.
Does anyone on the board have a 5 channel amp & a 2 channel amp that they can say the 5 channel sounds worse than the 2 channel?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I have a VEI Power Panel V-8000. This is a unit that has 8 output plugs each with its own individual switch. I plug all of my amps into this so that I don't turn them all on at once which can blow out a single switch. This unit plugs into one outlet of my Intinsic Sound power conditioner. I also have a power strip that I have 7 low current pieces such as pre-amps, tuners, CD player, etc. pluged into that I turn on all at once. The power strip is then pluged into the power conditioner. The power conditioner is plugged into the wall so the entire system only requires one wall socket. Phil
I used to have 4 amps besides the huge AVR, 1 for the rear channels and 1 each for FR, FL and center. All of that on top of a CD player, DVD player, sattelite receiver, outboard DAC, turntable, subwoofer. I had to cram a second audio rack in the already too small room and had freakin' wires all over the place. The hell with that ****......just 2 channel for now.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
