factory headunit/aftermarket amp
Systems
i posted this question in the sub forum, but this seems a more appropriate place for it. I have a 01 sentra with factory cd player, and i like it, it works fine. I dont want to get an aftermarket radio cause they tend to be "tempting" to theives. SO... i just got a set of db650's and 675's to replace my speakers and i was looking into an amp for them. I have some experience installing amps and speakers, but i was wondering how i could wire that up, cause im not sure if my stock radio has a "rem" output. I read that its possible to use a switched 12v line that connects to the rem input on the amp, but will that actually work?
Testing
Testing
Testing
Testing
Testing
First let me just say you should really reconsider not getting an aftermarket head unit. The difference in SQ between the speaker level inputs of your stock unit to a set of 4 volt passive pre-outs of an aftermarket unit will be a bunch. You can always take the faceplate off like I do.
The way I always did it was to run a wire from a fuse in the fuse box that came on with the ignition (I always used the radio fuse) to the amps remote input. This way the amp will turn on when the ignition is on. The downside is the amp will stay on as long as the ignition is on even if the h/u is off. Another reason to get an aftermarket h/u.polkaudio sound quality competitor since 2005
maybe i will look into it, whats a good brand to go with, i just need something fairly simple and not too expensive...
i just have this creeping paranoia cause a few of my friends stereos were stolen and they dont do a nice clean job of it, my one friend had most of his dashboard torn out... then again he was in the ghetto of philadelphia...Testing
Testing
Testing -
you also mentioned rca pre-outs, would i need 2 sets if i wanted to have all 4 speakers on a single 4 channel amp?Testing
Testing
Testing -
Originally posted by giggerman
you also mentioned rca pre-outs, would i need 2 sets if i wanted to have all 4 speakers on a single 4 channel amp?http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2 -
i was looking at h/u's and a few pioneers caught my eye, along with a blaupunkt... i heard of blaupunkt, but are they good?Testing
Testing
Testing -
i was looking at h/u's and a few pioneers caught my eye, along with a blaupunkt... i heard of blaupunkt, but are they good?http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Agreed. Alpine and Pioneer are at the top of the heap in my opinion followed closely by Eclipse.
Id stay away from Blah-punked.polkaudio sound quality competitor since 2005
im browsing through crutchfieldlooking at h/u, and as for the rca outputs some have "one set" others have "two sets" does "set" mean pair?Testing
Testing
Testing -
I would indeed assume that the 'set' designation means one pair. I second Alpine and Pioneer Premier. Alpine's new CDA-9855 (and CDA-9853) have a new cool touch-pad like control bar at the bottom - really neat to play around with. I'm using a Pioneer Premier DEH-P860MP and am very happy with it.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
I just installed the Alpine 9853 in my wifes car, I'm very happy with it. She loves it
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Yup, a set is a pair.
Youll want to get 3 sets. One for front, rear and subwoofer. This will leave you room for upgraded in the future. And look for voltages as high as you can. Try to get at least 4.polkaudio sound quality competitor since 2005
thats for the advice, i just gotta keep my eyes peeled now :-DTesting
Testing
Testing
