power amp
doug lang
doug lang Posts: 261
edited May 2005 in Electronics
Hey guys has any one heard of a rotel RB-965-AX 6 channel power amp. I have looked all over for spec's and can't find a thing. I even tried the rotel home page with no luck. Thanks in advance as always.
Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Post edited by doug lang on
  • okiepolkie
    okiepolkie Posts: 2,258
    edited May 2005
    Are you sure you aren't looking at the Rotel RB-956AX. This would be decent(not great) amp for the front stage of your HT. You could bi-amp the LSi's, or bridge the amp to get more power. I don't know anything about the sound quality of this particular amp.
    Zach
    Tschüss
    Zach
  • Tide
    Tide Posts: 154
    edited May 2005
    doug, I've got a RB-956AX amp, a RSP-960AX pre, and a RT-850A tuner running in my office with some vintage Polk Monitor 4s. I think the amp sounds great. Not a whole lot of power (I think the A, B, and C channels are all 30 wpc @ 8 ohms) but it is flexible enough that you can bridge the channels if you'd like.
    okie has linked the manual on the Rotel website.
    SDA 2s; HSU STF-2; Yamaha RX-V1
    SDA-CRSs; Polk PSW-303; Rotel RB-960BX; Rotel RSP-960AX;
    LSi 7s; Infinity PS8; Rotel RB-980BX; Rotel RSP-980
    Mirage Nanosat 5.1; Yamaha RX-V2300
    Monitor 5s, 5 jrs, & 4s
  • jmierzur
    jmierzur Posts: 489
    edited May 2005
    Zach
    It is NOT recommended to bridge the amp channels for 4 ohm loads. For the price, the amp does sound good.
