4 ohm's
doug lang
doug lang Posts: 261
edited May 2005 in Electronics
Hey I hate to belabor this but I have a question regarding the 4 ohm requirement for the polk lsi series. I am using a onkyo 989 receiver and the 4 ohms is not available with this receiver. My front speakers include a Lsi center and two more front Lsi's to follow. Can I power the three speakers with a preamp? Can I do this with a 2 channel or something higher. Any recommendations on what I can use. Thanks for your time, Doug
Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Post edited by doug lang on
  • Early B.
    Early B. Posts: 7,900
    edited May 2005
    I'd suggest getting a 3 or 5 channel amp for your speakers. The Lsi series are high quality speakers that need to be driven by high quality components to sound their best. To do otherwise is to defeat the purpose for buying them. MOST receivers will not drive them adequately and are not designed for it.
    "God grooves with tubes."
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2005
    That 989 was onk's top of the line if I remember right, it might be able to handle the load if you did not drive the speakers hard.
    As Early has suggested you really need a separate amp(s), use the preouts on the 989 and then it will serve as your pre processor.
    Their are many amps to choose from, you are looking for something with a high peak to peak amperage rating.
    RT1
  • Toxis
    Toxis Posts: 5,116
    edited May 2005
    it's not a preamp you need, it's just an amp. As already stated, find a 3 or 5 channel amp and be done with it. The 989 will drive them and sound pretty good but it will definitely be limited on headroom and sound quality. Adding an amp will make them come to life.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited May 2005
    Actually your manual does state dynamic power specs for 4 and 3 ohm loads. The problem is instead of handling dips to 4-ohm from 8 or 6, that'd be where you are starting.
    So yes, as said above, you can use it with LSi's, it's just a matter of whether it will be enough for you. It might be if:
    - you aren't looking for reference level HT experiences, and
    - your HT is in a smallish room, and
    - you're only running 5 ch's,
    then it just might be enough. And if a good sub is in the picture, it will relieve your Onk of some of the load and help it do a job that pleases you.
    If the Onk doesn't cut it for you, I'm not sure how much resale value is in it, but it is worth considering unloading it. Adding amps onto it's ****-end leaves alot of its value unutilized. That many AVR's are reduced to being a Pre-Pro is one of the biggest arguments against buying them in the first place... IMO.
    As for what to replace/ supplement the Onk with, if it comes to that. Well, that depends on your budget and your willingness to consider used gear.
    Naples, huh? You do any snook fishing?
    Welcome to Club...
    More later,
    Tour...
    Vox Copuli
  • doug lang
    edited May 2005
    Thanks again for all the replys regarding my question. I still can't believe the interest and time you guys put into this. This is a fine club and in just one week I have learned so much. Now for my 4 ohn deal, I probably will invest in a good used amp. I plan to replace my Rt35i's with the lsi7's, and just to be sure I will add on with an amp. Thanks again. Oh by the way the snook fishing is good in Naples, but the season just closed.
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
  • Tour2ma
    edited May 2005
    Keep in touch, Doug.
    And I went "swish polling" off the Naples pier with Grandpa a couple times back in the 60's. One of the best, lightest fish I've ever eaten...
    More later,
    Tour...
    Vox Copuli
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited May 2005
    If you can swing it, get the LSi9s instead. If you do a little research here you will find that the general consensus is that they are much better than the 7s.
    I am running my LSis with an Outlaw 770 which is rated at 300w @4ohms all channels and it works well.
    Welcome :p
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • doug lang
    edited May 2005
    Thanks tour2ma and wingnut you guys have been most helpful.
    Hey we are very lucky the pier is still there after last years storms.
    It sure is a hot spot for snowbirds. Take care, Doug
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
  • Toxis
    Toxis Posts: 5,116
    edited May 2005
    +1!!!
