chrysler 300c srt8 audio help
Systems
Currently working a 05 chrysler srt8 with the oem boston acustic 6 spkr + sub audio system. We are reusing the oem radio because of the nav. We have added in a component sys in the frt coaxial in the rear, a 4ch and mono amp. We used line output adapters directly after the oem amp for signal and are having some issues with interferance and sound quality. By sound quality I mean on the rear spkrs only if the balance is centered there is no mid range or low freq. response out of either spkr. But if you balance it to the left or right all the way both spkrs sound like they should. We are also having problems with the front mids having too much low freq. in them even with the amp set to high pass filters. If anyone has worked one of these cars and has any info that might help, please respond asap. I appreciate it in advance.
Testing
Testing
Testing
Testing
Testing
That is weird!
Im not sure what would make a speaker play highs only but when balanced to left or right they work fine. That should have no effect on them. When you turn the balance to the right its only muting the left and has no effect on the right side.
Off hand I would say the problem lies with the speaker level inputs. Those never work right and always let in a ton of noise.
I honestly dont know what to tell you since you need to keep the OEM receiver. I would almost guarantee that an aftermarket h/u would fix the problem.polkaudio sound quality competitor since 2005
pioneer makes a good nav system, too... or if you don't want the screen, there's double-din units that have a built-in screen (albeit tiny)...It's not good, very fundamentally simply not good. - geolemon
CCR,
I thinking your priority is wrong, the speaker input to your line converters is wrong / reversed. I believe you can prove this by removing all but one RCA input to amp, if the sound is ok for those speakers then we are on the right track.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Did you mean 'polarity'?
If so that wouldnt make a difference. Wiring one or more of your speakers out of phase wouldnt make one of them stop playing midrange. All it would do is have those out of phase speakers firing out of sync with the others and would give you some weird imaging.polkaudio sound quality competitor since 2005
Well yes, sorry to confuse anyone here, but been what he's doing I think it having a larger effect then just phasing. It's a simple error, and could have been over looked.
I'm looking at it this way the factory radio is bi-amp'd so the - / + of the speaker are floating above or below ground. He is hooking this speaker output from a factory radio converter to a grounded RCA Amp line input. He could even have a wrong type of converter that is not taking in effect of this floating bi-amp speaker output.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I get what youre saying.
The C400.4 has speaker level inputs. Why not bypass the line level converters altogether.polkaudio sound quality competitor since 2005
