adding a seccond power amp
goingganzo
goingganzo Posts: 2,793
edited May 2005 in Electronics
i found a adcom 7605 with is a 5 channel verson of my 7607. i am thinking of getting it and bi amping my front 3 and adding the 2 extra channels for the front efects. aucton starts at 400 should i go for it?
Post edited by goingganzo on
  • jmierzur
    jmierzur Posts: 489
    edited May 2005
    Have you thought of adding a better quality two channel amp for the L+R speakers for two-channel listening? This would still allow you to use your existing amp for the side effects speakers.
  • goingganzo
    edited May 2005
    i never 2 channel i use it for 99%ht and the rest for a party/cleaning
  • McLoki
    McLoki Posts: 5,231
    edited May 2005
    If you could get it for a good price, I would say try it. You could always resell it for close (if not more) than what you paid.
    I don't know if bi-amping will get you alot, but if you are running close (sound getting compressed at high volumes) it may help. Many would say just get a higher power amp to run your speakers and sell the one you are using. (similar to recommendation of running 1 10ga. speaker wire rather than bi-wiring with 2 14ga.)
    If you can get a good deal - I would vote for trying it. If it doesn't do what you want, sell both amps and get a single larger one.
    Michael
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2005
    I dont really think biamping for HT is going to do a whole lot for ya ganzo. But hey it would look pretty cool.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited May 2005
    Go for it!
    It will add another line to your signature and get you one step closer to the hardcores.:D :D:D
