best amp and preamp used for under $1200.00
sansui80
sansui80 Posts: 17
edited June 2005 in 2 Channel Audio
I have a pair of Klipsch klf 30's that two 12inch woofer and a 5inch mid horn and a 3 inch horn tweeter. Thease speakers can be biamped.
I would like to initially buy a amp + preamp combo and later biamp the speakers using a tube amp to run the top end?
I dont know weather or not to run a tube preamp .
I listen to 70 and 80's rock and modern Jazz.
Please give me some feed back. I want to make my purchase by 1st of june.
The speakers are very efficent. 1watt= 102 db.
I will use a cambridge audio 640c azur cd player and I need a good phono section and two preamp out put for multiple amps.
Thank you for your input in advance...........
Ben
Post edited by sansui80 on
  • George Grand
    George Grand Posts: 12,258
    edited May 2005
    Carver C-11 SS preamp with two sets of main outs.
    Carver TFM-35 SS power amp with 250wpc @ 8 ohms.
    Both pieces virtually unused. No original boxes but owners manuals are here. I am the only owner.
    $550 + shipping for the pair.
    George Grand (of the Jersey Grands)
  • audiobliss
    audiobliss Posts: 12,518
    edited May 2005
    I would say you'd be very happy stepping into the world of tubes since they match so well with Klipsch. I can't point at any equipment in particular, but tubes in general would be great. You don't need much power, either, since your speakers are so efficient. I'd head over to Klipsch's forum (here) and see what they say.
    Let us know what transpires!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Roy Munson
    Roy Munson Posts: 886
    edited May 2005
    George, is the TFM-35 a common ground amp? If so would you be interested in selling it seperately? I have a M 500t but it is non common ground and I can't use it with my SDA 2A's. Thanks
    2 Channel:
    Amp/Parasound Halo A23
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
    Turntable/AR XB-Shure V15 III
  • George Grand
    edited May 2005
    I believe it is a common ground amp, as Bob McG. was using one for awhile to drive his SDA's.
    As of this writing, the gentleman who started the thread is looking at a 1 Jun purchase date. If for any reason the transaction doesn't come to pass, yes I would consider selling the power amp alone.
  • Roy Munson
    edited May 2005
    George, if the deal falls through let me know..I am definitely interested in the amp! Thanks
    2 Channel:
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
  • George Grand
    edited May 2005
    Okay Roy.
  • Roy Munson
    edited June 2005
    George, I'm still interested in the amp!
    Check your PM's!!
    2 Channel:
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
