Rear center for LSi setup
edited May 2005 in Speakers
Hi,
I plan on running LSi-9 Fronts and LSi-FX Sides for a three row theater room and would like to have a center rear. I am thinking of using a single in-wall for the rear in the center of the rear wall. I have wired for three speakers on the rear wall to be able to do 1 in the center or 2 speaks, one on each side.
I can get a single TC265i for a couple hundred, or spend a little more for an LC65i, or even more for an LC265i.
The room is about 23' long by 13' wide. What do you guys think?
Post edited by gil on
Welcome!
    edited May 2005
    LC's are a better match to the Lsi's.
    edited May 2005
    Areed. If you're going all out for a full-on theater room, do it right the first time. Definitely the LC speakers would be best. Match those ring radiator tweeters all around for the best timbre matching.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
    edited May 2005
    Is one back good enough or is two a necessity? My current receiver is 6.1 with 6 internal amps.
    edited May 2005
    If you are doing a real theater (like you are), I would go ahead and get two. And get an amp if you are running all that off of a receiver. :)
Welcome!
Welcome!
