PSW10 Sub - Does it hum when not turned off?
lmpronto
lmpronto Posts: 33
edited July 2005 in Speakers
I've read user opinions where the sub hums when not turned off. Do all subs do this? Or just this one? Or is just isolated incidents? thanks
also, any personal reviews on this sub?
Post edited by lmpronto on
  • Toxis
    Toxis Posts: 5,116
    edited May 2005
    save more money and get a better sub.
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2005
    LOL Toxis. I'm sure that might be good advice, however, you didn't answer his question!
    He might not be prepared to get a new sub right now, so it would be helpful for him to know if this is something he will always have to live with until he is ready to upgrade.
  • lmpronto
    lmpronto Posts: 33
    edited May 2005
    does it hummmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm?
  • cnjvh
    cnjvh Posts: 253
    edited May 2005
    Most all subs emit a VERY faint hum when powered on with no input signal (faint like you have to have your ear practically to the woofer to hear it). That is normal. Cheaper ones may hum a bit louder but it shouldn't be something you hear from 5 feet away in a quiet room.
    A hum when the sub is on is different - this is from a ground loop in the system, most commonly from a bad cable TV ground. This is not normal.
    Can't speak to how this particular sub sounds as I've never heard one, however, most people will agree that Polk's most acceptable sub is the PSW505 which is a bit pricey :-(
    No earth robot is going to tell ME which button to press!!
    --Stuff--
    Front: Polk Audio RTi12
    Center: Polk Audio CSi5
    Surrounds: Polk Audio RTi8 (x4)
    Sub: SVS PB10-ISD (Dual)
    AVR: Denon AVR-3805
    Blu-Ray: Panasonic BD30
    Display: Sony KDL-55NX720B
    STB: Xfinity X1DVR
  • Willow
    Willow Posts: 11,257
    edited May 2005
    I can't never have either heard any of my subs hum. Not even my 202 when I owned it.
  • lmpronto
    lmpronto Posts: 33
    edited May 2005
    dunno, read reviews on this one where it has 'port noise'
  • Willow
    edited May 2005
    there is a difference between humming and port noise
  • Mjr7531
    Mjr7531 Posts: 856
    edited May 2005
    Port noise happens when the sub is firing away and displacing more air than the port can handle quietly. There's no chance you'll notice hum if you are hearing port noise, and vice versa.
  • lmpronto
    lmpronto Posts: 33
    edited May 2005
    ok, well anyone hear anything like hum with this sub?
  • gazix
    gazix Posts: 10
    edited July 2005
    I have that sub, it hums (I can hear it from 5 feet away)
    Looking around for a solution...
  • Andrzej
    Andrzej Posts: 8
    edited July 2005
    I have a bigger brother, psw12, and there is no hum even when my ear is next to the sub (LFE input if that matters). I agree with cnjvh that it might be a ground loop problem if you can hear it few feet away.
  • gazix
    gazix Posts: 10
    edited July 2005
    Found an extension cord that has the ground wire pulled out, and tried plugging the tv, then the subwoofer into it (each being the only device into the ext cord) and it still buzzes.
    Would this still be considered a ground loop problem?
  • fergusonv
    fergusonv Posts: 3
    edited July 2005
    Sounds to me like its defective
  • gazix
    gazix Posts: 10
    edited July 2005
    talked to polk and they said it shouldn't be buzzing (after a few emails trying different things). Will this buzzing be harmful to my sub? If it is just an annoyance then I can deal with it for a few years untill I buy upgrade to a new one (and send this in for repairs :)
    Having to pay for shipping and being without a sub for who knows how long sucks so bad.
