DIY Cables
Skynut
I am thinking about building my own cables just for S#!T's and giggles and was wondering where is the best place to buy components. I am thinking about using Silver wire and plugs so I may check out the impact silver has.
Any suggestions where to get the best price?
Any suggestions which components are best?
Any personal experiences would be appreciated.
Actually I should have said I want to build interconnects, not speaker cables.
My Bad.
My Bad.
Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking
Post edited by Skynut on
Unless you're going to be disconnecting and reconnecting your speakers a lot, there's no reason to add any connectors. The more you add the more resistance your putting into the wire. Keep it simple, it will sound better.
My Bad.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking -
Check out Homegrown Audio. They have DIY silver interconnect parts. Let us know what you think of them if you try it out.
http://www.homegrownaudio.com/ -
Thanks, the wire here is a lot cheaper than I have found elsewhere.
I will let everyone know how they come out.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Cool. I've been wanting to try them out myself. Cool looking stuff.
Paul -
So??? I'm dying to know how they turned out?
I have RTi8's, CSi5, SVS 12 inch box sub, Denon 3805, and FXi3's as rears... (Well, soon will
) I need something fairly cheap, but that sounds good, as possible. Checked out the Signals, they seemed ok, but fairly expensive i thought. Ebay possible for ok cables??
ThanksHonoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier
