Ohm Rating
Systems
Systems Posts: 14,872
edited May 2005 in Car Subwoofer Talk
Is it ok to run 2 4ohm polk momo's (MM2124DVC) on a polk momo amp (C500.1 Monoblock Amp) in a 2ohm wiring setup. i have been riunning 1 momo (MM2124SVC) and i have blown 4 of them (burnt voice-coil) alredy running a 4ohm load.
Testing
Testing
Testing
  • exalted512
    exalted512 Posts: 10,734
    edited May 2005
    yes
  • neomagus00
    neomagus00 Posts: 3,899
    edited May 2005
    double dagger (yes?):
    burning a VC has nothing to do with the load on the amp, beyond the fact that a lower load means higher power, to a point. and yes, the 500.1 is rather powerful :).
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited May 2005
    You may want to reset your gains. I find it very unusual that you received 4 bad Momo's. Sounds like your asking your amp to produce more than in can at that load. Meaning that it is seeing a lot of distortion, and or a clipped signal.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
