WTB: Power Filter
gwh
Looking for a power filter in the strip form, open to all brands.
I have shopped Ebay and AG but thought Id see if anyone needed to unload one here first.
Got a slight buzz up front and a hum in the sub when the microwave runs. Thought Id try the lazy man approach before I start running dedicated AC wires and such.
Thanks,
G
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
How much you looking to spend?
I know Brett can get some at good prices if you want a new one.Tschüss
Zach -
Thanks for that info, I'll see what he can do.
In the meantime I'll consider all offers to sell.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
I have a panamax 5100 power filter, in excellent shape 170.00 oboshipped to your address, with insurance. Let me know.
CRj -
Crj,
Im still kicking your offer around, not ignoring you.
Any others?
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Panamax 1000 shipped for $120 obo? This one is especially cool if you have a switched output on a receiver or something. It has an extra cord to plug into a switched outlet which acts as a switch to provide a high current output to amps or whatever. Of course all the filtering...
madmax
Edit: Oh sorry, not really a strip. It is about 17" wide, 1 1/2 inches tall and maybe 6 or 7" deep. Has outlets all along the back, both switched and unswitched and I believe a switch and some LED's on the front.Vinyl, the final frontier...
I am looking for a decent power filter as well. Is there any problem hooking up a large external amp (high current) to these filters or do you still recommend plugging them straight into the wall?
Michael
If anyone else wants to jump on the offerings go right ahead, no harm as far as Im concerned.
Im real indecisive at this point, still looking at a lot of options.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
It depends on how "high" of a current it is. For example my Carver mono blocks peak around 1400 watts each. They should be plugged into the wall or a "passive" filter which can supply as much as the circuit they are plugged into. Other high current amps may be plugged into a strip or component unit which supplies as much power as is required by the amp. It all depends on what your amp says it requires which is normally listed somewhere around where the power cord or fuse is.
Michael
something like a PS Audio Ultimate Outlet High Current (15A or 20A) is what you need. I use one and it works well. Check out PS Audio website for details.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
Found a sweet deal on a PF, I'm out of the hunt.
Thanks for the offers.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
