How sensitive are you
Willow
Willow Posts: 11,231
edited May 2005 in Speakers
My question is about sensitivity on speakers.
What is considered low, average and high. What difference does it make and how much difference does it make ? Does 2 dbls of sensitivity make a difference on the receiver for example ?
Post edited by Willow on
  • gatemplin
    gatemplin Posts: 1,595
    edited May 2005
    Hey Willow,
    Sensitivity is the output per a certain voltage (often 2.83 IIRC) at one meter. So low impedance speakers will play louder.
    Efficiency is the ouput per watt and at one meter which is usually how speakers are rated.
    IMO near 80 dB/ watt is very low, around 90 is high, but some are over 100 db/ watt.
    The ratings aren't really directly comparable between speakers. Some speakers are designed without baffle step compensation which inflates the efficiency. Also, speakers run into power compression at different points. So a lower efficiency speaker may pass a higher efficency one as compression sets in.
    Graham
  • unc2701
    unc2701 Posts: 3,587
    edited May 2005
    This is fairly ballpark, but:
    89-92 is average; 88 & less is low
    usually you see 94db+ speakers labeled as high, but for true flea power you're going to need more like 98db. With 16watts a 98db speaker will give you the same volume as a 89db speaker with 128 watts.
    Of course, it also comes down to the room size & volumes you intend to play them at.
    edit: those low/mid/high figures I gave are for modern speakers... used to be that speakers were pretty inefficient.
    Backburner:Krell KAV-300i
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2005
    Subjectively speaking, 86dB and below would be considered "low" efficiency; 87-89dB would be "average" and above 89dB is usually considered "high" efficiency.
    For someone with "typical" hearing, it usually takes an increase/decrease of 3dB to notice an audible difference, but some are more sensitve to level differences.
    Efficiency has no bearing on sound quality. It's simply the nature of the specific design; although higher efficiency speakers do require less amplification to reach the same SPL's.
  • Willow
    edited May 2005
    Thanks you all for the info , I was never clear on that, now I'm half clear :D
  • steveinaz
    edited May 2005
    The quick down and dirty is this, efficiency is the loudness in decibles, at 1 watt (2.83v), 1 meter from the speaker.
  • jcaut
    jcaut Posts: 1,849
    edited May 2005
    At the risk of making this overly technical...
    I think efficiency and sensitivity are getting confused, in the definitions above. Voltage sensitivity is how many decibels of sound, of a specified frequency or range of frequencies, would be produced by a loudspeaker with a given input voltage (usually 2.83 Vrms), measured on-axis at a certain distance (usually 1 meter).
    Power sensitivity is the same thing, except that the input signal is given in Watts. Since power can be expressed as volts squared, divided by impedance, -- the voltage level required to produce 1 Watt is the square root of the impedance that it is driving. So, 2.83 Volts is 1 Watt at 8 Ohms. 2 Volts would be 1 Watt at 4 Ohms, etc..
    Efficiency is a little bit different and is usually only given for individual drivers and not for a speaker system -- That's why sensitivity and efficiency are usually taken to mean the same thing when talking about a speaker system.
    Efficiency is usually expressed as a percentage, and may be used to calculate the theoretical voltage or power sensitivity of a driver. The equation takes into account things like compliance, free-air resonance, and electrical resonance magnification (Qes), and generally assumes that the speaker in question is near a wall or on a baffle of sufficient width to produce 2pi radiation at the frequencies being tested.
    I may be wrong here, but I think most manufacturers of hi-fi speakers take the woofer or woofers sensitivity, as calculated from efficiency and assuming 2 pi radiation, and use that as the stated sensitivity. The speakers might not actually acheive that in the real world. Some may actually measure it. I think for PA speaker systems, where real-world volume is more important, it's usually measured.
    Sorry for the length :)
    But to answer the original question: Real-world power sensitivity of 88 db or above, is what I would consider pretty high, for a home hi-fi speaker.
    Jason
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2005
    You must also factor in the "type" of speaker. A Klipsch and an SDA rated the same efficiency will not sound the same at 1W/1M.
  • audiobliss
    audiobliss Posts: 12,518
    edited May 2005
    :eek: Someone said Klipsch! :D:D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • madmax
    madmax Posts: 12,434
    edited May 2005
    will they both be the same perceived loudness?
    Vinyl, the final frontier...
  • dorokusai
    edited May 2005
    If by "perceived loudness" you mean, will I be able to sit in my usual listening position? Hell no....the Klipsch will adjust you into a new area.
  • gidrah
    gidrah Posts: 3,049
    edited May 2005
    Not usually. 95dB on decent horns won't be perceived to be as loud as 95dB on conventional speakers.
    Make it Funky! :)
  • dorokusai
    edited May 2005
    I guess my Klipsch demos in-house, Heresy/KG4/KG5.2/Forte/KLF30 is crazy talk. I assure you it adjusts your listening position regardless of "known" volume dial spinning. Granted it's not scientific, but the physical movement of my listening position in relation to the speakers was very important...and there have been a couple speakers running through here from time to time.
    If there is no perceived difference then why bother owning speakers other than Polk?
    A horn load to soft dome tweeter....seriously, you think there is no difference in "perceived" effect? Soundstage wise there is no change?
  • brettw22
    brettw22 Posts: 7,623
    edited May 2005
    I have nothing to add technically, so I'll just say.....
    I'm NOT.....(sensitive).... ;)
  • gidrah
    gidrah Posts: 3,049
    edited May 2005
    My not usually was in reply to MadMax. Heck yeah there will be a perceived difference. Just like there would be between horns and electrostatics.
    Make it Funky! :)
  • dorokusai
    edited May 2005
    G - Just trying to clarify, nothing but words here. It wasn't anything but a comment. I wasn't sure where your comment was directed, my fault.
    F1nut Posts: 51,746
    edited May 2005
    From my experience, Klipsch horns will back you up. :D
  • gidrah
    gidrah Posts: 3,049
    edited May 2005
    Not a problem buddy. Just 2 guys typing a reply at the same time. Hell, I would've wanted clarification too.
    Make it Funky! :)
