Best In Wall Setup Polk or Klipsch?
jack08501
jack08501 Posts: 2
edited May 2005 in Speakers
Hello,
I am new to in wall home theater, and I am setting one up in my basement as we speak. I am going to use in-wall speakers for all five channels and I have narrowed my search down to Klipsch and Polk.
System 1- Klipsch R-5800-W for front and center speakers, R-5650-W for the rear surrounds.
System 2- Polk TC265i for the front and center, TC65i for the rear surrounds.
One of my questions is if you think the Klipsch R-5800-W will work well as a center channel when flipped on its side. The advantage I see with the Polk is that the TC265i sets up on its side like a traditional center channel. Does this make a difference?
BTW- My room size is 19X18, I have a dedicated sub and a Denon Receiver.
Thanks!
Jack
Post edited by jack08501 on
  • danger boy
    danger boy Posts: 15,722
    edited May 2005
    well lets see.... this is a Polk Audio speaker forum.. so i'm thinking most people in here would like Klipsch better than Polk. :rolleyes:
    PolkFest 2012, who's going>?
    VR3 Posts: 29,401
    edited May 2005
    +1 :p
  • jack08501
    jack08501 Posts: 2
    edited May 2005
    Funny replies but no serious answer
    Jack
  • Frank Z
    Frank Z Posts: 5,860
    edited May 2005
    Although you may hear from a few happy Klipsch owners here, the overwhelming majority will recommend Polk. Don't take it the wrong way, we're Polk fans through and through so it's only natural that we'd recommend 'em.
    SCompRacer Posts: 9,089
    edited May 2005
    Hi Jack. I'm new to in-wall/ceiling speakers too. Just finished a 14' x 22' family room with Polk LC65is for fronts/center and LC60i's for rear in ceiling. I listened to the RC's first, but after hearing the difference spent more 'future' money to get the LCi's.
    Have you had a chance to audition either of your choices yet? I had to do a bit of driving to find stores that had in wall speakers set up. Ended up buying them at a Tweeter store. They had like three brands of in-walls set up.
    EDIT: Before I covered the walls and ceiling, I built ideal volume enclosures for the speakers. The Polk manual tells you the size. They have a custom enclosure for the in-walls, but they were too costly for me.
  • gregure
    gregure Posts: 871
    edited May 2005
    I think the Polks would be far superior to Klipsch, just because I hate the Klipsch sound-way too bright. Looks like the Polks would be a nice choice w/ the silk tweeters, as I work around such speakers all day long from Speakercraft, and those silk tweeters are really nice.
    However, I think the LC series w/ the ring radiator tweeters would be better, and be even more superior to Klipsch.
    If you want to go really nice, look into the Voyage in-walls from Martin Logan. Very detailed, very accurate, w/ Transducer film tweeters/mids, tweeters being aimable as well.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • aaharvel
    aaharvel Posts: 4,489
    edited May 2005
    i'm in agreement with Gregure.
    Klipsch's have bright sound characteristics- and unless you have them hooked up to a dark-sounding receiver such as a Marantz or whatever then you're going to get a bright sound, and inside a wall would make it even worse (worse for me as I don't like bright sound, if you like it then get the Klipsch)
    Polk speakers, hooked up up to most any type of receiver/amp - at least to me seem to sound more natural and much less fatiguing over time than any Klipsch speaker.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • wallstreet
    wallstreet Posts: 1,405
    edited May 2005
    I've never been impressed with the Klipsch inwalls. If you go a little off center the treble drop off is very noticeable. This is a critical component of inwalls since you can't (usually) aim the speaker toward the listening position. I know the Polk has an aimable tweeter, but I'm not sure about the Klipsch.
    Jack
    But if you really want an answer go listen to the speakers and decide for yourself. Klipsch inwalls can be heard at UE and Polks can be heard at Fry's. What difference does it make what I think?
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited May 2005
    Check out some in-walls by Sonance. I got a pair of these and I'm quite impressed with the sound, quality and features. has trebble attenuation: +/-3db or 0, and you can angle the tweeter. Very nice in deed ... anyway...just some food for thought. BTW...they were not much more then the compatable Polks.
  • hoosier21
    hoosier21 Posts: 4,415
    edited May 2005
    I was going to ask "why not ask the folks at Klipsch" but I see you did.
    http://forums.klipsch.com/idealbb/view.asp?topicID=65080&sessionID={3BE8F9A3-E5DA-45F3-B4EB-AB1D64918B21}
    Anyway, that is a question only you can answer, how could anyone know what is best for you? Do your best to research, demo, and buy what you feel is the best for you.
    Have fun shopping.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • wallstreet
    edited May 2005
    I also own 4 Paradigm Reference inwalls the outperform my Polk ab755's.
  • audiobliss
    audiobliss Posts: 12,518
    edited May 2005
    Considering the design of the Klipsch in-walls (with the Tractrix horn), I imagine turning it on its side (for the center) would change the sound a bit. I wouldn't imagine that would change the sound of the Polk in-walls, though.
    As to which set would be better, that's really up to you and your ears. As you can see by my sig, I'm a happy Klipsch owner. I also like the Polk speakers I've heard (and the Paradigm, Energy, and Wharfedale speakers I've heard, too........dang...I'm not nearly discriminating enough.....:p). If I were you, I'd try to demo any in-walls you can find and spend a lot of time listening to both music and movies through them to see which one sound better to you.
    Let us know what you decide to do!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Shell
    Shell Posts: 134
    edited May 2005
    SCompRacer, is right check out the LCi polk series. Also, since you are finishing your basement install the speaker enclosures you do hear a noticeable difference.
