Can you put stuff on top of an SVS cylinder sub?
Hi all,
I have a PC Ultra on the way and was wondering if it's OK to put things on its top surface. I downloaded the manual but didn't see anything about this. I have a small, 12" TV sitting where the sub will go and ideally I would want to put the TV on top of the sub as space is pretty tight.
Thanks for any input.
Multichannel Music:
Sony SCD-C2000ES SACD
Denon 3803 AVR (pre/pro duty)
Outlaw 755 amp
Outlaw ICBM
Polk LSi15/LSiC/LSi9 (front/center/surround)
SVS PCU
HT:
Sony 9100ES DVD
Outlaw 990 pre/pro
Outlaw 7100 amp
Panasonic TH-37PX50U plasma
Polk RTi8/CSi5/RTi6/FXi5(front/center/surround/back)
SVS PCU
Outlaw 755 amp
Outlaw ICBM
SVS PCU
HT:
Sony 9100ES DVD
Outlaw 990 pre/pro
Outlaw 7100 amp
SVS PCU
Post edited by bertram on
I don't think i would do it.. it may rattle something loose in side the TV. like it may cause it over long term to be out of color.. or something like that.
If space is limited.. build a shelf above the SVS.
or get one of those wall brackets. since it sounds like the TV isn't to large.PolkFest 2012, who's going>?
or get one of those wall brackets. since it sounds like the TV isn't to large. -
I like to set my wife in a mini skirt on top of my dual CS+ and play the ring drop over and over:D***WAREMTAE***
Originally posted by Polkmaniac
No.
If Polkmaniac's response wasn't clear, then as an owner of two PCU's, I will clarify what he means - NO! Find another spot for the TV. You will understand why when you get the sub delivered. -
Did you purchase one of the new Box ultra's or a cylinder? If box - you might get away with it. (but I still wouldn't) If cylinder - no way. (ports face up, driver faces down)
Michael
edit: just read the title of this post "Can you put stuff on top of an SVS cylinder sub?" I'm an idiot - and no, you can't do it. if you choose not to believe us, just e-mail svs.....Mains.............Polk LSi15 (Cherry)
The top is a thin metal grill, not designed to hold anything. Also, you've got three 3" ports that move a lot of air. It must be kept clear.For rig details, see my profile. Nothing here anymore...
