How do I hook up 6.1 to this receiver i bought?
lmpronto
http://www.yamaha.ca/av/Receivers/Back_Panels/HTR_5760_Back_Panel.asp
it does up to 7.1, but i only need 6.1. i dont see a rear center in the back of the receiver. how would i hook it up so theres only 1 back center?
as u can tell, im noob
Post edited by lmpronto on
http://www.craneaudio.com/home-cinema/dolby_7.1_surround_sound.asp
the 7th speaker uses the same signal as the 6th, dual rear centerDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
oh so if i plug in only my rear speaker into the left rear center, i wont be missing out on any "right" rear sound effects?
no, it's a dual mono signal, both the same (rear center)
5.1
The 5 is
Left channel
Center channel
Right channel
Surround Left channel
Surround Right channel
Add a sub for your .1
add rear center you got the sixth channel
add a second rear center you got the 7th channelDodd - Battery Preamp
oh, i thought 6 and 7 were left and right rear centers. but they output the same thing
My denon gives me the option to run 5, 6 or 7.1. Check to see if your Yamaha will do the same. I know Onkyo and HK do not give you that option.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Originally posted by Toxis
My denon gives me the option to run 5, 6 or 7.1. Check to see if your Yamaha will do the same. I know Onkyo and HK do not give you that option.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
