HK Refurb 135 vs new Onkyo sr502
Schris22
Heres the deal,
Looking at these two. Both are around 220. Which one?
lots of info about what I need in this thread.
Here
Edit: Now I am also looking into the Denon AVR485S refurb. Thanks for the info though.
Thanks,
Chris
Here
Thanks,
Chris
Receiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Post edited by Schris22 on
for me, i much prefer Harman Kardon receivers over Onkyo for both movies and especially music, at any price point. Whereas Harman has a nice, warm analog type sound - Onkyo receivers at least to me are bright and processed in their sound - (IMO)
Harman rates their wattage specs more accurately, as well. The h/K will rate all channels driven SIMULTANEOUSLY -throughtout the ENTIRE 20hz- 20khz range.
A bottom rung Onkyo receiver like the 502 will rate it's 75 watts at 1channel driven at a time at 1KHZ only, much like Sony, Kenwood and a few Pioneers and Yamahas. I can only guess that this is due to the lack of current in their amplifiers.
If you can squeeze a little more out of your funds, i'd go to J&R.com and spend a benjamin more and get a BRAND NEW 235 instead of a refurbished 135 for 7.1 (not 6.1), Prologic IIx, higher current and wattage in the amplifiers and most importantly PREOUTS- so in case you ever want to upgrade to more powerful amps in the future. That was the dealmaker for me.
right now you can buy a brand new 235 at jandr.com for $350- regular price $500. Brand new, with warranty.
if you ask me that's a steal. better performance, and it gives you a path to upgrade in the future if so desire.
whichever brand you choose- good luck.
Onkyo. I think they both sound pretty close to each other but the Onkyo is much easier to use and the remote isn't the most retarded thing on the planet.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
no arguement there. Harman's 135 remote is retarded in it's layout.
(edit) Denon's are really sweet dude. they're my 2nd choice. a VERY close 2nd choice. -
wow never even looked at the remote control. I've been focusing on the receiver.
how much frusteration is that remote?
hmmm, Tough decisions.
ChrisReceiver: Onkyo TX-SR502-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt -
the 135 's remote is more frustrating at the onset.
the button's are kinda small.
me, i'd rather take the time to learn a remote and get better sound. and in the 235's case (with a slightly better remote) the confidence in knowing i can hook up separate amps to it via PREOUTS. -
i don't think anytime I will be using a seperate amp. Just no need for it when i'll be in small rooms for at least 7 or so years. Speakers are polk audio r50's csi1 and r15
Thanks for the recommendation. debatingReceiver: Onkyo TX-SR502-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
i've heard that Denon's amp sections are just as high quality as H/K. plus i believe the Denon has 75watts x6 into 8ohms. whereas the H/K puts out 40x6 into 8ohms. The Denon also has prologic IIx, whereas the H/K 135 has only prologic II.
If you want a warm sound- go with H/K.
If you want a bright sound (feh) -go with Onkyo.
If you want a Neutral sound- go with Denon.
EIther the H/K or Denon will sound great with your Polk speakers. I myself have RTI's and F/X's across the board. Even though I own a H/K- honestly- i would chose the Denon.
