Ute Setup
Systems
Systems Posts: 14,873
edited May 2005 in Car Audio & Electronics
Hi everyone,
I have a question Im working on a new ute. I would like to make a set up of the following;
head unit ( dvd integrated would be nice but not essential )
splits for front
something for the rears
Sub/s that would be in the tray
Along with however many amps to power this properlly. Akthough I could probably only fit 2 amps.
Could I get some recomendations please on what models etc people think I should get for a budget of maximum $3500 US
Thanks very much in advanced
Testing
Testing
Testing
  • MacLeod
    MacLeod Posts: 14,358
    edited May 2005
    Off hand I would recommend any Alpine head unit that met your features and budget requirements. Polk Audio MMC6500 components, MMC5250 coaxials for the rear, Polk Audio C400.4 for power.
    I dont know what you mean by subs in the tray but if you want dual subs how about dual Polk Audio MM2104's run off the C500.1?
    Other amps worth mentioning would be Xtant, Alpine V12, MTX Thunder, JL Audio.
    Other sub and speakers I would recommend would be JL Audio, Boston Pro's, MB Quart anything, Morel and Focal.
  • swerve
    swerve Posts: 1,862
    edited May 2005
    circuit city it having clearance on ESA tube subs. 9 bucks... you can't really go wrong man...
    -adam
    cats.vans.bag...
  • MacLeod
    edited May 2005
    Maybe if they paid me $9 bucks to take them off your hands. I bet they would make a good door stop, or maybe tie a chain to it and use it for an anchor.
