svs pb2
bvette94
I recently bought an svs sub and my question is do i set the crossover switch to enable or diasble. and can anyone explain what this does. i am using a denon 5800 receiver.
thanks for any help
Bob
thanks for any help
Bob
Post edited by bvette94 on
disable, use the xo in your receiver....the disable switch bypasses the xo in the sub. since you will be usins the one in your receiver you don't want to you the on in ur sub, that would filter the signal twice and thats no good.
Thanks i will make sure it is disabled.
FYI, the only reason you would use the XO on your sub is if you had no line out on your receiver, or chose not to use it, and ran speaker cables from your receiver to your sub then out to your speakers.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
I connected my velodyne sub to my Denon's FRONT PRE-OUT connectors. That way it gets the same full-range signal as the front speakers. I use the crossover in the sub to roll-off its response above 42 Hz.
I like to drive my fronts full range and therefore don't want to use the receiver's crossover (which often has only a few crossover settings, such as 80Hz). If you have smaller fronts, then using the receiver's crossover makes more sense.Multichannel Music:
Sony SCD-C2000ES SACD
Denon 3803 AVR (pre/pro duty)
Outlaw 755 amp
Outlaw ICBM
Polk LSi15/LSiC/LSi9 (front/center/surround)
SVS PCU
HT:
Sony 9100ES DVD
Outlaw 990 pre/pro
Outlaw 7100 amp
Panasonic TH-37PX50U plasma
Polk RTi8/CSi5/RTi6/FXi5(front/center/surround/back)
SVS PCU -
thanks for the examples it makes things more clear.
Bob -
I have recently discovered by enabling the crossever on the sub and setting the crossover to 80hz that the base is much titer and cleaner it is an imediate diffrence at all listining levels!
it seems to remove a static like sound in this setup!
try it both ways and see for your self!PROCESSOR-- Sherbourn PT-7010A
AMP
Sherbourn 7/2100A
DVD
DENON 3910
BLU RAY
PS-3
PROJECTOR --- Panasonic ae-900u
SPEAKERS
Klipsch Ultra2 System
92" Screen
PS Audio power cords
Buttkickers
