Morel Pulse 6
Systems
Systems Posts: 14,873
edited May 2005 in Car Audio & Electronics
hello everyone,
i want to find out if "Morel" is a good and known company for car speakers, does anyone here know it? or can find out if it's reliable
i want to buy their "pulse 6" component speakers, which are cheaper but have 120 rms which is much higher than the rest at those prices.
thanks everyone :)
Testing
Testing
Testing
  • neomagus00
    neomagus00 Posts: 3,899
    edited April 2005
    morel is a pretty good company... i knew they had a car line, but i've never heard anything about it, good or bad...
    hope this helps :D
  • MacLeod
    MacLeod Posts: 14,358
    edited April 2005
    Morel makes an AWESOME speaker. The Elate series are just about the best sounding speakers on the planet. The best way to describe them is "smooth". Smooth as silk they are.
    If your choice is Morel or anything else, its gonna be hard to not choose Morel.
    Check em out here.
  • Systems
    edited April 2005
    thanks for the replies!
    although i cant find in the website you gave me the Morel Pulse 6,
    i'm trying to understand how it has 120 rms when the rest of the speakers at the same price has about 40...
    if any of you find the specifications of these speakers plz tell me.
    thanks again! :)
    Testing
    Testing
    Testing
  • MacLeod
    edited May 2005
    Go to that website and click 'Enter the new Morel car line'. The Pulse series is all the way on the left of the page.
    VR3 Posts: 28,775
    edited May 2005
    Morel is a well known DIY company, with tons of offerings on Parts Express
    www.partsexpress.com
    They are used in tons of DIY projects, usually for high output/low xover points. As they manufacturer pretty big dome tweeters (not like a cone) That can be crossed low (lower than normal) and can handle extroidinarially loud volumes and power...
    They are also known the be smooth, I don't even think they offer a metal dome tweeter.
    I wonder how Parts Express HA DIY drivers would work in a car, as long as they were a 4 ohm model - which they have plenty of.
  • audiobliss
    audiobliss Posts: 12,518
    edited May 2005
    Originally posted by Vr3MxStyler2k3
    Morel is a well known company
    Oh. So that's why I've never heard of them before. lol
    Interesting; I'll hafta check 'em out.
    oby, how much are they? And what, specifically, are you comparing them to?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
    VR3 Posts: 28,775
    edited May 2005
    Maybe I should of thrown in "Among DIYers"
    The DIY drivers are expensive...
  • audiobliss
    edited May 2005
    You implied that; you said that they were a very well known DIY company. I just chose to edit that out of your quote. :D
    It is interesting, though, how all the specs for their component speakers are in PDFs. At least it doesn't take Acrobat Reader as long to load up on the second, third, fourth, etc. time as it does on the first....
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
    VR3 Posts: 28,775
    edited May 2005
    I seriously have to wonder if these web guys that make these PDFs actually ever load them...
    If they did, they would quickly NOT use the...YUCK
  • neomagus00
    edited May 2005
    i've got Adobe Reader on my startup list... with all the other stuff on that list, the reader's pretty much transparent, and i don't get the crazy-long startup time when i download the first pdf of the day
  • audiobliss
    edited May 2005
    So you mean to say that you have it running in the background, hogging resources and making everything else run slower? I'll just avoid PDFs, thank you. :p
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • neomagus00
    edited May 2005
    it takes up less than 20 meg of memory, and i force it into the pagefile more often than not... i think that in terms of the gig i have, it's inconsequential :).
  • audiobliss
    edited May 2005
    Yeah, probably so. I, however, only have 512MB of w/e cheap ram Compaq threw in the case. :(
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
