Hey T.U.I. listen up::
sgtgto
Hi:
Do me a favor. Put your RT55s on stands or whatever and set them on the inside, about 8" from your RT2000s, and not quiet level at the top. Connect them in parallel and let me know what you think.
Gary:p
Gary:p
Post edited by sgtgto on
I recently put my rt25's on top of my rt1000's. I ran parallel witch gave me 4ohms. My Onkyo handeled it well but got a little warmer than usual. Checked the manual and it strongly suggested against any load under 6ohm. So I then ran them in series which gave me a 16ohm. Reciever runs much cooler now. Did not notice very much differnce in sound. I am very happy with the results. Plenty of volume and clarity.
Hi:
Scott, you need to put them alongside the RT1000s and slightly below the top of the 1000s, 8 or 9 inches apart.
Gary -
sgtgto- have you tried a side by side comparasion between running the dual fronts on each side; side by side vs. stacked???
just curious? i am running rt800i/rt35i's stacked, and i was very happy with the results and the greater detail this set-up provided. i believe you are running 2000's and 800's, and i am assuming you too, are happy with your results, i'm just curious if you have tried a 'stacked' method against your side bye side? -
i've updated my system showcase pics.:D -
you should buld a custom grill for them
hell they look 50 feet high!! might as well get another sub and stack the speakers on them.
scott;) -
Doing this doesn't have any cancelation effects? Maybe I should stack my RT25i's on top of my RT55's...thoughts?
Peace Out~:DIf...
Ron loves a film = don't even rent. -
When I first got my RT55's I stacked them on stop of my RT800's just to I could use the RT800's speaker wire to test them out. That was a scary proposition since the RT55 is significanly wider than the RT800. I had the Leaning Tower of Polk that thankfully didn't come tumbling down. I never tried playing them together. Someday I'll try it, but side-by-side.
Aaron -
ron, give it a shot. adding the 35's to the 800's greatly improved the highs and midrange. test it out, see what you think and let me know your thoughts on it...
on the side by side vs. stacked, i haven't demoed them against each other, but in theory, is there a reason one should be better than the other? thoughts?
goingganzo-don't they look great 'naked' though???:D
wangotango68- the angle of the shot is helping the height, alonst had the digital on the floor for 'effect':rolleyes: check out the system showcase, you can see how they look from behind the 'sweet spot'... -
Juice, do you have these running in parallel, series, or are you A+B'ing these? Please, pardon my prying.
wiring in parallel...(it's my only option)
A/B played simultaneously downgrades to a stereo downmix on my rec. in 5.1 applications...
works well, no over heating...yet:D -
Ron - If you do this let me know what you think. I have considered trying this since I can get a pair of rt25is very reasonable right now. I had a pair of large Advents with a pair of AR 4x sitting on top. I could connect one to the A and and one to the B and play them at the same time. They complimented each other very well and sounded really good together. This was in a old stereo 2 channel setup."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Hi:
The stack method doesn't work to produce what I am looking for, A broader sound stage. When you stack them you are also way above ear level which isn't good. To get the proper sound stage they need to be side by side. Try it and you will see what I mean.
Gary -
i will play around with my placement a bit when i get some free time, hear what the differences are for myself. the height isn't (too) bad for my application, although ear level is preffered, my center has to sit high on my entertainment center. it is tilted down towards the listening position, but the 'stacked' method has the tweeters are a relatively close horizontal level...
nevertheless, i am going to experiment with this...:D -
I had my 800's running with my 1000's at the time.. it sounded ok.. but I like them stacked better.. sin my 55's are upside down now..its more at ear height..
oh..I have nor room to put them on stands next to my 2000's anyway... -
you can put something under your chair cushin so you can set higher. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces. -
i would rather buy a beter main like the ls instead of running dual fronts just my thoughts
I cant argue with that last statement...but since I already had the 200i...and needed to trade in my fx/300is for something... I figured why not
with the Lsi's..I would need an amp that can run 4ohms..wich I do not have... -
yeah, i would prefer the LSi's too over the 800/35 combo, but i had the 35's available after getting the 1000's. it sounds good for now, the LSi's are awhile off for me...
I've got my Acoustiflex sitting atop my 10Bs. Man is this ever good. Now listening to one or the other pales in comparison. I also turned the Acoustiflex over. Before I turned them over it sounded blurred. Probably time delay problems. Now the space between the tweets is at ear level.
I have them hooked-up A/B, but my JVC uses the rear amps for the B so I can adjust the volume independently and have the Polks at 6ohms and the Acoustiflex at 8ohms. But I can only listen to one pair in 5.1, but I can switch between the 2.
Edit: Mouse died. Reboot, etc. I have B (sub-room) pre-outs. If I hooked up another amp I could listen to both sets as fronts in 5.1 I'm thinking about a 200/ch Denon if I can talk my buddy into it, or a multi-channel for the house like the 12 ch Niles.Make it Funky! -
Hi:
I keep saying it and I will again. You need the speakers side by side. Having them on top of one another is an improvement, it doesn't compare with side by side.
Gary:D -
sgtgo//// u keep saying its better on the side... but did you put your 800's on your 2000's? In my room...what I have is working just fine..in your room..what you have is fine... green apples to red apples..bottom..line... apples.. :cool:
Hi TUI:
All i'm saying is try it.
Gary:p
