Sonic impact MOD *pics*
faster100
faster100 Posts: 6,124
edited May 2005 in 2 Channel Audio
I have needed something to do for awhile.. a project of some sort. well i needed a amp for the bedroom rig and had no money.. so i bought a sonic impact amp from think geek and for some reason it only charged me 22 bucks + ship, when it was posted 34.99, so great deal for me... Hooked it up when it came in, sounded great.. my homemade PS wasnt enough power so i happen to have a 13.5 volt 14 amp stand alone Ps i used to use when i was into CB's years back.. cut the cord and plug off a wall wort that didnt work and bingo!!! plenty of power... that works great. no distortion like when i used the underpowered supply first.. so i found a project box and went to Good ol radio shack for some parts... did the project last night. it still works so thats a good sign.
went to binding post, separete power switch w/blue LED power light.. at this point i just left the original volume pot inside the case glued down as i dont know how to bypass it.. I stuck with the pcb mounted audio input because i couldnt find any insulated rca panel mount jacks.. and also installed a new power jack, i just hooked it onto the battery power wires beings the stock one is pcb mounted and this wont use batteries anymore.. the box is small... about 3" x 4" x2" high nice and compact aND the LED even after i installed a resister is very bright.. that looks really cool at night... anyways here are the pictures for anyone interested in modding one.
I plan to have a guy i know make a custom logo/name out of vinyl sticker like the kind you get for your car, SO ANY SUGEGSTIONS ON A VERY SMALL GRAPHIC OR NAME LET ME KNOW..
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by faster100 on
  • faster100
    edited April 2005
    2
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited April 2005
    3
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited April 2005
    4
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited April 2005
    and yall know what the stock looks like
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • organ
    organ Posts: 4,969
    edited April 2005
    Nice, the new look is nice with the Dodd. If I were you, I wouldn't bother with the custom logo.
    Maurice
  • faster100
    edited April 2005
    actually this amp is for the bedroom rig with a parasound pre, but it does look cool next to the dodd.
    I think it looks cool and for being so small it sounds good, surprised it didnt get more comments.. Not on my work but on the amp itself..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • phoneisbusy
    phoneisbusy Posts: 867
    edited April 2005
    There's been some positive feedback on the amp here. I think Madmax was playing around with one. Replacing the pot for the volume can apparently improve the sound too.
    As long as you had fun with it. ;)
    regards
    Dave
    Time is the best teacher. Unfortunately it kills all its students.
  • faster100
    edited April 2005
    yeah waS a cool project, ive never really done any diy projects...
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited April 2005
    Im running the sonic impact on a pair of Rt25i's with a parasound 850 pre and my old fisher tuner.. I left the stock input and use a hard adapter 1/8" to 2 rca adapter to the interconnects.. sounds good and i power the Si with a nice power supply thats 13.5 volt 14 amp, so it never distorts... not so far anyways.. That blue led is bright as heck.. nice light and i like the simple plain front of the box.. it even has little vents on the sides.. its really smaller then the picture looks.. about 2 packs of Cigarettes thick and a tad wider
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
    heiney9 Posts: 25,221
    edited April 2005
    Sweet little project...when are you going to mass produce them? At least make a limited edition run for the forum. Again nice tidy work...Enjoy!
  • michael_w
    michael_w Posts: 2,813
    edited April 2005
    Looks good.... anyone know if there is a dealer in Canada that sells those amps? I'd like to get my hands on one and maybe try some diy modding but don't want to have to cross the border with it.
  • unc2701
    unc2701 Posts: 3,587
    edited May 2005
    Nice! I'm gonna have to give this a try... but with the P/S bolted to the top of it (I HATE wallwarts).
    Backburner:Krell KAV-300i
  • faster100
    edited May 2005
    I want to make a matching power supply some how and to fit in a case like that... would look pretty cool, maybe with a red led for the PS.... this thing still amazes me and it drives the speakers albeit pretty small ones really loud and clean...
    I say find your own project box and hit radio shack or parts express and build it yourself.. don't spend 400 bucks on a modded one.. ive seen several things online and the prices for what this is, crazy!!
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited May 2005
    Well tonight i did some more mods, I tore it all apart and removed the 1/8" input jack, redid the power to the board hard wired.. removed the volume pot/power switch and hard wired those wires back together for full volume with no pot in the circuit... Now it has a monster pigtail from a nice Y adapter i had , 2 female rca's out the back instead of the headphone jack... sounds pretty good, about the same but with better connections all around... I did away with powering it through the battery wires and wired it straight to the board... ok well should be fine for awhile till i find another article :D
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • audiobliss
    audiobliss Posts: 12,518
    edited May 2005
    Does that mean that it's either 'on' or 'off'? Why would you do that?
    ....more pics.....!....:D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • faster100
    edited May 2005
    To take garbage out of the signal path, I wired a switch on the side of the case for off/on so it does have a off/on switch just not the cheap one that came with it. I'll have to take some better pictures and update the thread
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • audiobliss
    edited May 2005
    lemme clarify:
    You said you removed the volume pot/swith and replaced it with an on-off swith; does this mean that you no longer have control over the volume?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • faster100
    edited May 2005
    Correct :)
    Its now a full on amp, not an integrated type amp. I use it with a parasound pre, so no need for a volume.
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • audiobliss
    edited May 2005
    Ahh...I totally forgot about a preamp there for a minute. :rolleyes:
    Can ya tell my experience has been restricted to receivers? :p
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • faster100
    edited May 2005
    here are some new pics
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited May 2005
    and the power unit
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • audiobliss
    edited May 2005
    :eek: big power unit
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • faster100
    edited May 2005
    for now, I'm going to get a wall wart soon and do away with the huge power supply :D
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
