Set up advice
Willow
Willow Posts: 11,340
I have my rti8's now and an energy s10.2.
what would be the advantage of running the 8's on small ? or on large. Many of you will say try it and see.
I can't turn the xover off on my reciever so it's fixed at 80hz.
would the 8's benefit from being set to large ? would the sub benefit from the 8's @large ? what about the reciever ? would the reciever rather push all the bass to the sub ? or share with the 8's.
And lastley on the BM on the receiver Should I set the bass to
1-sub only
2-both?
Post edited by Willow on
  • Pinktulip7
    Pinktulip7 Posts: 249
    edited April 2005
    Dude u came to the right place,If u r using RTI8 as a front L/R set them large and rest of the speaker's small that way low frq. will be sent to Sub.
    TV :>Panasonic TC-P55VT50
    RECEIVER :> HARMAN KARDON AVR 7300
    FRONT :> L & R :> POLK RTI A9 500 W
    AMP :1> PARASOUND HALO A21 250 W
    AMP :2> EMOTIVA UPA-1 200 W
    CENTER :> POLK LSiM 706c 250 W
    SURROUND SIDE :> POLK RTi A3 150 W
    SURROUND REAR :>POLK FXI A6 150 W
    DVD PLAYER(HD) :>TOSHIBA HD X-A2
    DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
    POWER CONDITIONER :> PANAMAX M5400-EX
    SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
    SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
    billbillw Posts: 8,107
    edited April 2005
    Willow,
    You should experiment with setting the fronts between large and small and see what sounds better to you. I suspect they will sound better set to small. Let the sub do the majority of the deep bass and let the 8's do the midbass and highs.
    One advantage to setting the fronts to small is you free up amplifier headroom for the rest of the frequency range.
    For the BM setting on the receiver, I would read the manual and see what it says about that setting. It could determine whether the crossover is applied to just the sub or all speakers, which is what you want if you have small surrounds. OR, it could determine whether the sub gets bass from all channels or just the LFE track on movies. That is why you need to read the manual.
    FYI, the sub doesn't care whether the fronts are set to large or small. It has a separate amp and should receive the same load no matter what the setting is.
  • Frank Z
    Frank Z Posts: 5,860
    edited April 2005
    I know that I'll get flamed for this, but here goes...
    Get off yer' lazy a$$ and try it both ways ya deaf bastage!:D
  • Pinktulip7
    edited April 2005
    take it easy Frank.
  • Frank Z
    edited April 2005
    You must have missed the post count this newbie has...and the smilie too.
  • McLoki
    McLoki Posts: 5,231
    edited April 2005
    Willow -
    I am not familiar with your AVR. I would suspect that your best sound will be from setting your speakers to small and letting your sub handle the low frequencies. If you have separates or a high-end avr, I will change that comment to let them run full range.
    Making the best sound will come from the combination of your AVR and your speakers (source shouldn't affect this question). If you don't have a high end amp, give it a break and set the speakers to small, if you do - might as well get everything the speakers can give (and set them to large).
    Of course that is all speculation, just to be safe do what frank said... :D
    Michael
  • Nelson57
    Nelson57 Posts: 190
    edited April 2005
    Hey Willow
    I have my RTi8s set to small. Tried both large and small, and at least in my setting I get better detail in movies when set to small. Let the sub handle the bass.
    Main theater: Paradigm Studio 100's v4 L/R, CC690 Center, ADP 590 x4 Surrounds. Dual Outlaw LFM-EX-1's, Yamaha Aventage RX-A1010 as Processor, Anthem PVA-7 Amp
    Secondary System: Polk RTi 6 L/R, CSi3, Center, FXi3 x4 Surrounds, Def-Tech Supercube II, Pioneer Elite VSX-23 Receiver
  • Willow
    edited April 2005
    :eek: :D
    I know I played with it last night a tadd as I will again. I was just curious as to how other had it set up.
    Looks like I did come to the right place ;)
  • Willow
    edited April 2005
    ok receiver is cut off at 90hz and is this way all the time and can't turn it off. So I am using the unfiltered of the sub. 90 seems a bit high ! can't we localise 80-90 (+)
  • Willow
    edited April 2005
    I don't want to but would I be best to use high level (speaker wire) or use the 90hz xover ? (I would rather use rca input and not the high level)
    edited April 2005
    Willow,
    What receiver are you using?
  • Willow
    edited April 2005
    Rxv 540 :(
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited April 2005
    If the sub is up by the speakers, I wouldn't worry about the 90 X-over.
    When I added a sub to my 800's, the X-over at 80 really helped open them up in the mids. That would be my vote...
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • Willow
    edited April 2005
    the sub is right by the front right one
    edited April 2005
    Don't worry about the 90hz, stick with the pre-amp level input. Using speaker level inputs, you would only get the bass from the front 2 channels into your sub. 80hz would probably be ideal, but 10hz won't make that big a difference.
  • Willow
    edited April 2005
    Thanks for all the help..
    I will try small and sub out only not both
  • Willow
    edited May 2005
    I have played around and set all speakers to small, it took a tadd of oumph out of the mains but cleared it up a bit. I have it set up for sub out only and not both. Quite enjoying the sound and receiver is pushing them just fine and no excessive heat.
