6.1 DTS, what is the sixth speaker?
masterpp
masterpp Posts: 9
edited April 2005 in Speakers
The dvd movies that contain DTS 6.1 & dolby Digital, I wonder what is the 6th speaker? I only have 2 floorstand, 2 rear ceiling, center & sub.
Should I choose dolby digital 5.1 or DTS 6.1?
by the way, why is rear sounds so low than the rest?
I haven't seen any movies that provides 7.1.
Post edited by masterpp on
  • lomic
    lomic Posts: 407
    edited April 2005
    The 6th channel is Rear Center. If you don't have a rear center, select 5.1, though if you select 6.1 I doubt there will be much difference.
    Rear channels aren't as loud because they're suppose to create envolping sound without the listener being conciously aware there is sound from behind. Only specific sound effects like birds chirping, creaking boards etc will actually announce they are coming from behind, but they should still not draw people's attention from the front stage if used properly.
    There isn't currently a format (that I'm aware of) for 7.1 discrete playback - 7.1 is done by the reciever/processor messing with the 2 rear channels to create an even more complete sound field.
    Dodd Audio ELP [ Tubes ] // Harman Kardon AVR330 // Parasound HCA-1203A // Denon DVD-2900
    Polk Audio LSi9, LSiC, LSi 7 // HSU STF-2 // Signal Cable Interconnects (SG BW/A2/MP)
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited April 2005
    You may need to calibrate your speakers with an SPL meter http://ubb.outlawaudio.com/ubb/ultimatebb.php?ubb=get_topic;f=15;t=001495
    You can get one from Radio Shack pretty inexpensively. If you are in a position to obtain a 6th speaker for 6.1, you should. It sounds really nice and fills up the rear soundstage with a more realistic movie-going environment. (I have 7.1) But, in the meantime, select 5.1.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
    billbillw Posts: 7,560
    edited April 2005
    It doesn't matter which soundtrack you select on the DVD.
    Generally the DTS soundtrack will sound better than the Dolby Digital. Don't worry about it having a 6th channel of info. Your receiver setup has a setting to specify whether or not you have a rear channel (if your receiver is 6.1/7.1 compatible). If you feed a 6.1 DTS-ES signal, it will simply ignore or mix the rear channel to play in your surrounds.
    FYI: The DTS will sound better because it has less compression compared to DD.
