polk mm12 freq response question
Scoop
Scoop Posts: 5
I had a bass test cd and the mm12 was poinding...
i realized i had the subsonic filter on, 20hz-50hz was off.
Heres a little of my situation, I am running the sub off speaker wire line-out-converted to RCA, going to a RF amp and to the sub. I'm not sure on the voltage but the L-o-c is supposed to drop it from 20 to 5-8. Anyhow, its not RCA setup because my car has fiber optics and you basically cant do it...
Will the sub be fine playing 20hz to 50hz? or is it safer to just leave it off?
Post edited by Scoop on
  • Airplay355
    Airplay355 Posts: 4,298
    edited April 2005
    how does a subsonic filter filter from 20-50 hz? subsonic is below 20 hz, what kinda weird car audio **** is goin on?
    and you sub should be fine, there is no purpose to getting a sub if you are going to cut off frequencies below 50hz, thats nuts. subs are made to play that low. while yours might not go all the way down to 20 hz, it will go lower then 50 lol.
    you should probably post this in the car audio section though, just incase i have no idea what im talking about.
