My RTi12s need some power!!!
Vgamer4550
Hey all, I am looking into purchasing a pair of RTi12s.......I've been goin back and forth between the 12s, 10s, and 8s and I dont think I can pass up the raw power that is the 12s.
That being the case.....I know my Denon 3805 AVR will run a set of RTi12s enough to get sound out of them but I need some suggestions to help make them really shine.
I was looking into picking up a pair of Outlaw Monoblock Amps; but they are only rated at 200watts a piece. Being as though I will have one for each speaker is that going to be enough to really make them sing or should I be thinking about another Amp all together.
I want the most bang for my buck here and price is kinda an issue. At $299 I thought that Outlaws were a great little amp to get my hands on. Let me know what you guys think. Thanks again.
Post edited by Vgamer4550 on
those monoblocks are great for your rti12's. 200 watts will make them sing like a fat lady at the end. you might even be able to get b stock outlaws, then youd have an even better price
Get the Outlaws!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I have the RTi12's hooked up to a Pioneer 1014.I just ordered some Outlaw 200's......Go to their site and you get free shippng...That's a saving of $31 per amp.Panasonic 50" Plasma + Pioneer 6010
Toshiba XA2 HD-DVD
Panasonic BD30 Blu-Ray
Pioneer 1014
Polk RTi12 (front)...Polk CSi5 (center)
Polk RTi4 (rear)...Velodyne DLS 5000-R Sub
3 Outlaw M-200 Amps -
Agree on the 200 wpc being plenty.
For music, I like the RTi10's better myself... the 12's bass seems a little bloated to me. The 10's are just tighter.
For HT, the 10's are a better choice as well, IMO. With a decent sub in the mix, if you run mains set to small, you'll never use the added bass that comes with the 12's.More later,
Tour...
Vox Copuli
thanks all......I just auditioned the speakers this afternoon and I think the RTi10s might be the way to go for me at least.....
I plan on getting an HSU VTF3 MKII sub for my system and I think the 12s are just a little too big for my needs. That is one massive speaker.
So if I am going to go with the 10s.....does it make sense to still get myself a pair of the M200s? Whatcha guys think. -
I think you're a very astute auditioner..
As for the amps, you're in the right power range. If you want new, bag the Outlaws. If you're open to used, there are other options that'll land you even more power for less than $598.More later,
Tour...
Vox Copuli
