Speakers
Systems
If you had to choose from Alpine Type-R's, Audiobahn Aluminiums, and Momo Subs which makes the best 10" for the cost?
Testing
Testing
Testing
Testing
Testing
Hard to tell, what kind of enclosure you putting them in? Truck, Car? I would say...in my opinion, MOMO or Type-R. Not a fan of the Audiobahn. I like both the Type-R's and the MOMO's, and would give the MOMO's the edge because of the cleaner sounding bass. Type-R's do have more wiring options, but are about 3/4's of an inch deeper so they are less versitile, but a little less expensive. My choice would be the Polks, but I think you'll be very happy either way.Testing
Testing
Testing -
www.carstereotime.com has the mm100s for $175 per speaker with free shipping
i too think the momos sound better than the alpine but i also think you should hear them both for yourself depending on what music you like, how much space you can take up, and what kind of enclosure youll need/want
hope i could be of help
-cody -
I am putting them in a 1997 Honda civic. So it is between Alpines and Momos?Testing
Testing
Testing -
Definately should be between Polk and Alpine. If you're looking for sound quality, definately the MOMO's, but if you want pure SPL, Type-R's may be a better choice, they do get louder, but you lose some of the sound quality. Both excellent sounding subs though. Like Cody said, you should definately try to hear them both. I know this is still probably no help... Sorry.Testing
Testing
Testing -
Lemme cut to the chase, if you can shell out the few extra bucks, go with the momo's!Testing
Testing
Testing -
