HDMI/DVI Cable
mark g. nelson
I just picked up a 52" JVC HDILA and I have ordered a 811 receiver from Dish Network. I will need a HDMI/DVI cable for it. Is Monster the best way to go or is their a better choice out their. AT $150 for the monster 4M I do not want to do this twice. Thanks
Post edited by mark g. nelson on
don't support monster.....check www.ac4l.com for cables
Monster makes a decent step up from the buttom of the barrel but their pricing is a touch out of whack for what you get and they're marketing is evil.
Look around a bit a do some google searches. You'll find some better options. Another general rule: the longer your cable is, the more important quality becomes.
I think you can do much better than $150 for that level of cable.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
Check computer stores like Microcenter. "Digital" connections don't have to be expensive.
Does it have to be a 4m cable? I have several DVI cables that were part of computer monitors that were never used if that'd work, but they're like 5-6 feet.comment comment comment comment. bitchy.
Originally posted by mark g. nelson
At $150 for the monster 4M I do not want to do this twice. Thanks
You can do this three times for the price of one Monster cable with the same or better results.
Blue Jeans Price List
No BS Cable Info -
Thanks guys for the help . I thought there had to be a better way .
Brett,
Yes it does need to be 4m. I am going to put my receiver in the AV rack. My CS1000p Takes all the space in my TV Stand. So the long cable it is. Thank You very much for the offer.
The forum is still the best place for honest advice. Thanks -
Mark, how do you like that JVC? Any problems with it? Where did you buy it?Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688 -
Mark,
I am using a 50ft Key digital HDMI cable with a DVI to HDMI converter. Eventually the dish boxes will go HDMI, I recommend not going with a cable that is set with this configuration. My 811 looks great with a converter and this cable. I have a 62" Mitsubishi DLP with no signal loss. I bought mine from http://www.digitalconnection.com/products/cables/kdhdmi.asp"The only way to get rid of a temptation is to yield to it." -
Mark - what stand are you using for your TV? I'm looking at getting a big screen between now and Christmas, and I'm very limited to which stands I can use with the CS1000p (I'm sure you also went through this).Brian Knauss
ex-Electrical Engineer for Polk -
Cobalt Cables has an excelent DVI cable . I replaced my Monster DVI with one and even my girlfriend noticed the difference in PQ. They don't have an HDMI yet though. I wish they did.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
